zmc crash ?????!!!!!
The Zmcd.log
Server starting at 05/12/13 20:58:07
'zmc -d /dev/video1' starting at 05/12/13 20:58:12, pid = 10849
'zmc -d /dev/video1' started at 05/12/13 20:58:12
'zmc -d /dev/video1' crashed at 05/12/13 20:58:12, exit status 210
'zmc -d /dev/video1' starting at 05/12/13 20:58:12, pid = 10852
Can't select: No child processes at /usr/local/bin/zmdc.pl line 593.
Server starting at 05/12/13 20:58:13
'zma -m 1' started at 05/12/13 20:58:16
'zma -m 1' starting at 05/12/13 20:58:16, pid = 10875
'zma -m 1' crashed at 05/12/13 20:58:16, exit status 210
'zma -m 1' starting at 05/12/13 20:58:16, pid = 10877
'zma -m 1' crashed at 05/12/13 20:58:17, exit status 210
Server starting at 05/12/13 20:58:18
'zmc -d /dev/video0/' starting at 05/12/13 20:58:21, pid = 10904
'zmc -d /dev/video0/' started at 05/12/13 20:58:21
'zmc -d /dev/video0/' crashed at 05/12/13 20:58:21, exit status 210
'zmc -d /dev/video0/' starting at 05/12/13 20:58:21, pid = 10905
Server starting at 05/12/13 20:58:22
'zmfilter.pl' started at 05/12/13 20:58:25
'zmfilter.pl' starting at 05/12/13 20:58:25, pid = 10930
'zmaudit.pl -d 900 -y' starting at 05/12/13 20:58:34, pid = 10943
'zmaudit.pl -d 900 -y' started at 05/12/13 20:58:34
'zmwatch.pl' started at 05/12/13 20:58:36
'zmwatch.pl' starting at 05/12/13 20:58:36, pid = 10949
'zmwatch.pl ' stopping at 05/12/13 20:58:50
'zmwatch.pl ' died at 05/12/13 20:58:50, signal 14
'zmaudit.pl -d 900 -y' stopping at 05/12/13 20:58:50
'zmaudit.pl -d 900 -y' died at 05/12/13 20:58:50, signal 14
'zmfilter.pl ' stopping at 05/12/13 20:58:50
'zmfilter.pl ' died at 05/12/13 20:58:50, signal 14
Server shutdown at 05/12/13 20:59:00
Why this problem ?
With Xawtv , i view perfecly all 8 channel !
Why this problem ?
- zoneminder
- Site Admin
- Contact:
I have Suse 10cordel wrote:I have a question.
On what distro?
What is the card config?
Is this zm from source or RPM?
What version?
Regards,
Corey
The capture cards is two UCC4 conexant chips 878a
The UCC4 have 4 composite channel input.
I have configured the bttv driver for 105 card ( Provideo PV143)
Provideo is equal as UCC4 card , IMHO
Zm is 1.21.4 from source.
The name of device is : /dev/video0 , /dev/video1 & working with xawtv
for all 8 composite channel. ( 4+4)
what resolution you trying to capture on what pallete
James Wilson
ok, the size & pallet for all input non change.cordel wrote:zmc will crash if setting are that which the card don't support. If it works in xawtv then it will work in zm. The other thing to pay attention to is that the 878 chip don't like having different setting across its inputs, so all inputs on video0 should be the same size and pallet.
The problem persist
Zmc crash with a perl problem ? ( es: modules missing , old version , bad install perl , ecc ecc )
mudule perl-time-hires (downloaded, not present in suse 10 package)
the cause of this problem ?
