Page 1 of 3
Debian installation Manual (New release)
Posted: Thu Dec 15, 2005 9:56 am
by Koenzie
Hello Everybody,
I've made a full manual for the installation of ZM running on Debian.
Because i cant find a good manual on the internet i want to share mine.
Here is the link (incl. mirrors) :
http://www.zoneminder.com/downloads/Zon ... nstall.doc
http://217.154.38.122:8080/ZM_Utils/Zon ... nstall.doc
http://rapidshare.de/files/9204432/Zone ... l.doc.html
If somebody else can host it on their server, please do so and post the link
You can post your comments and additions here.
I hope you all can install zm succesfully with this manual
Good Luck !
Greetings,
Koenzie
Posted: Thu Dec 15, 2005 10:03 am
by cordel
Thank you Koenzie for that.
I now it will help out.
If you are not able to maintain the web page, I might be able to get a wiki up on mine and post this in it. That way it would be available and you could make changes as needed.
Regards,
Cordel
Posted: Thu Dec 15, 2005 10:06 am
by Koenzie
cordel wrote:Thank you Koenzie for that.
Regards,
Cordel
The manual is on rapidshare (free file sharing) and i dont have webspace to put it on. Can you host it for me cordel ?
Posted: Thu Dec 15, 2005 10:20 am
by cordel
Yeah I can. I'll have to get something loaded for it on the server. The only thing there now is a doc manager That I haven't even used. I'm thinking wiki so that it's easy to edit.
Posted: Thu Dec 15, 2005 10:25 am
by Koenzie
cordel wrote:Yeah I can. I'll have to get something loaded for it on the server. The only thing there now is a doc manager That I haven't even used. I'm thinking wiki so that it's easy to edit.
Oke, sounds great, maybee for the time you can just host the doc file ? Rapid share is not so easy and stable
Posted: Thu Dec 15, 2005 10:30 am
by jameswilson
if you want i can have it here too
Posted: Thu Dec 15, 2005 10:32 am
by Koenzie
jameswilson wrote:if you want i can have it here too
Yes please, more mirrors is always better
Posted: Thu Dec 15, 2005 10:40 am
by jameswilson
http://www.jpwilson.eu/ZM_Utils/ZoneMinder_install.doc
Is the easier way of getting it.
Now hosted on my server too
Great manual mate looks great, if i used debain would definetly use it
I especially like the useful info on setting the motion detectetion up. ;-)
Good work mate
Posted: Thu Dec 15, 2005 10:43 am
by Koenzie
jameswilson wrote:http://217.154.38.122:8080/ZM_Utils/Zon ... nstall.doc
Good work mate
Tnx for hosting, the motion detection setup is set up by default, i'm planning to a a section there to fine-tune these settings
Posted: Thu Dec 15, 2005 10:46 am
by jameswilson
i was only pulling your leg mate. im useless at writing manuals but yours looks good. Ill host it here as long as that server stays alive and my static ip remains constant. Im thinking about putting a webpage up on it with links to stuff instead of just folders but thats for when i have time
Posted: Thu Dec 15, 2005 11:02 am
by zoneminder
Everyone seems to be doing the same thing! I've put it up at http://www.zoneminder.com/downloads/Zon ... nstall.doc and added a comment and link to this thread from the Documentation page.
Rapidshare certainly make you jump through hoops to download it though!
Phil
Posted: Thu Dec 15, 2005 11:52 am
by Koenzie
zoneminder wrote:Everyone seems to be doing the same thing! I've put it up at http://www.zoneminder.com/downloads/Zon ... nstall.doc and added a comment and link to this thread from the Documentation page.
Phil
It's not a bad thing to have some mirrors
Tnx for putting it up also
Excellent
Posted: Fri Dec 16, 2005 7:55 pm
by johabba
Really nice and easy howto.
I can mirror if you like. Straight download...no fuss.
Just PM.
Posted: Thu Dec 22, 2005 9:33 pm
by tux
thanks for manuall.
- I test it under debian stable/testing without x.
- First I try with debian stable, but versions of libc6, libgcc1 and libstdc++6 are old for zm .deb.
#apt-get install zm
zm: Depende: libc6 (>= 2.3.5-1) pero 2.3.2.ds1-22 va a ser ins-talado
Depende: libgcc1 (>= 1:4.0.0-9) pero 1:3.4.3-13 va a ser instalado
Depende: libstdc++6 (>= 4.0.1) pero no va a instalarse
- Then I upgrade to debian testing and is running ok.
- Version of zm packet(deb) is 1.21.3 because I cannot see timeline:
#apt-cache show zm Version: 1.21.3-4
- Somebody try upgrade to new version 1.21.4 ?? i tried with:
#zmupdate.pl --version=1.21.3 --user=zm --passw=zmpass
Can't locate LWP/UserAgent.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.7 /usr/local/share/perl/5.8.7 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at /usr/bin/zmupdate.pl line 181.
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 181.
ZM readme
zmupdate.pl –version=<previous version> [--user=<db user> --pass=<db password>]
LINE 181 of zmupdate.pl
use LWP::UserAgent;
my $ua = LWP::UserAgent->new;
$ua->agent( "ZoneMinder Update Agent/".ZM_VERSION );
thanks and sorry for my bad english.
Posted: Thu Dec 29, 2005 5:51 pm
by tim@pcs-alaska.com
I love the idea of having a Debian Doc.
Curious if anyone has tested this doc?
Thanks for your hard work!
Tim
OOOOOPS!
Please disregard I see two people have voted that it works!
Best,
Tim
