Working Kodicom 8 chip 8 port board
pcalleros
Post by pcalleros »
Purchased a Kodicom (?) clone with 8 chips and 8 ports. Device I am using is 132. I am using with a P4 1.8/512 Meg machine. It appears to multplex IRQ's and that was giving me many issues when first installed. I purchased board for $100 USD which is good but I would stick with maybe the 4 port 4 chip clones in that they are much easier to configure.
The picture quality from 4 b/w cameras is very good though. Each of the 4 b/w cameras are outdoor Optex combo IR Motion and cameras. I have had issues getting X10 to trigger alarms.
tux
Post by tux »
- Are you runing with 8800R ? (8 ch 240 fps, definig card=102)
http://www.linuxtv.org/v4lwiki/index.ph ... icom_4400R
- Or 4400R ? (16 120fps, defining card=132)
http://www.linuxtv.org/v4lwiki/index.php/Kodicom_4400R
thanks for your information.
pcalleros
Kodicom
Post by pcalleros »
I could not get the card to run with 8800R (102) just 4400R (132) on initial configs.
Once installed (think I tried about 4 new builds)
Now stable will try to change device to 102 to see what happens.
pcalleros
8800R
Post by pcalleros »
Card has been running with no ill effects using 102 for last few hours. Currently buffers are set to 4. Will change buffers to 32 and post results.
pcalleros
8800R
Post by pcalleros »
I have it running with the latest LiveCD. (kernal and insmod). Last night tried to increase buffers to 32 and that errored out with multple errors so that ZM would not boot at all. Brought buffers back down to 4 and it is working again. Will be adding a 5th camera this week to it.
pcalleros
Kodicom
Post by pcalleros »
Dec 22 03:15:12 ICS-ZM kernel: Linux version 2.6.12-12mdk (apatard@n1.mandriva.com) (gcc version 4.0.1 (4.0.1-5mdk for Mandriva Linux release 2006.0)) #1 Fri Sep 9 18:15:22 CEST 2005
Dec 22 03:15:12 ICS-ZM kernel: BIOS-provided physical RAM map:
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 000000001fff0000 - 000000001fff8000 (ACPI data)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Dec 22 03:15:12 ICS-ZM kernel: BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
Dec 22 03:15:12 ICS-ZM kernel: 0MB HIGHMEM available.
Dec 22 03:15:12 ICS-ZM kernel: 511MB LOWMEM available.
Dec 22 03:15:12 ICS-ZM kernel: On node 0 totalpages: 131056
Dec 22 03:15:12 ICS-ZM kernel: DMA zone: 4096 pages, LIFO batch:1
Dec 22 03:15:12 ICS-ZM kernel: Normal zone: 126960 pages, LIFO batch:31
Dec 22 03:15:12 ICS-ZM kernel: HighMem zone: 0 pages, LIFO batch:1
johabba
how many cameras
Post by johabba »
pcalleros,
how many cameras have you been able to use with this board?
sugacapra
me too have bought the card...
Post by sugacapra »
pcalleros, please may you report in the step you had to do for having the card work ?
i've bought a similar in ebay today, will arrive in about (hope.. *crossing finger*) 7-10days... i will have to prepare to a hard fought? :?
pcalleros
Kodicom 8 Chip / 8 Port
Post by pcalleros »
I have tried up to 6 cameras and they all work well.
Currently have only five cameras hooked up to it.
Looking at boot up the card appears to multiplex IRQs.
When configuring Linux video driver I configured what appeared to be one card for every port.
Just tried 30 FPS and works well.[/img]
