hi, i'm getting this error message, got any idea on how to fix it ?
Do i just have to restart the configuration process of zm ?
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /home/netbijoux/zm-1.21.3/web/zm_db.php on line 21
Could not connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
mysql_connect
mysql_connect
Regards,
Sophak
Debian stable 2.6.8-4-k7 kernel - logitech pro 4000 X 3 - zoneminder 1.21.3
Learning Php / Mysql / Java /
Sophak
Did you make sure that mysql is started?
Regards,
Corey
Regards,
Corey
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
user@host:/root$ /usr/sbin/mysqld
051229 14:11:02 [Warning] Can't create test file /var/lib/mysql/netbijoux.lower-test
051229 14:11:02 [Warning] One can only use the --user switch if running as root
/usr/sbin/mysqld: File '/var/log/mysql/mysql-bin.1' not found (Errcode: 13)
051229 14:11:02 [ERROR] Could not use /var/log/mysql/mysql-bin for logging (error 13). Turning logging off for the whole duration of the MySQL server process. To turn it on again: fix the cause, shutdown the MySQL server and restart it.
051229 14:11:02 [ERROR] Aborting
051229 14:11:02 [Note] /usr/sbin/mysqld: Shutdown complete
so... yes, it's not started and it doesn't want to
Regards,
Sophak
Sophak
ok, i'm trying with mysql 4.0.25
after unpacking i launch that mysqld it's give me :
host:~# /usr/bin/mysqldumpslow
/usr/share/man/man1/mysqldumpslow.1.gz
Can't find '/var/lib/mysql/*-slow.log'
host:~# /usr/sbin/mysqld
060102 12:53:21 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
060102 12:53:21 InnoDB: Starting log scan based on checkpoint at
InnoDB: log sequence number 0 44812.
InnoDB: Doing recovery: scanned up to log sequence number 0 44858
InnoDB: Last MySQL binlog file position 0 79, file name /var/log/mysql/mysql-bin .000099
060102 12:53:21 InnoDB: Flushing modified pages from the buffer pool...
060102 12:53:21 InnoDB: Started; log sequence number 0 44858
060102 12:53:21 [ERROR] Fatal error: Can't open and lock privilege tables: Table './mysql/user' was created with a different version of MySQL and cannot be read
InnoDB: buffer...
Regards,
Sophak
Sophak
