Hi all,
My old RH9 box shat itself recently and I'm in the process of setting up a new FC4 machine.
So has any kind soul created a ZM RPM for FC4, ordo I do it the old way?
Kind regards and Happy New Year to all.
Colin
Fedora Core 4 RPM
It will be a bit before a new RPM comes out. I've started work on it but I have to work out the database stuff since zmconfig.pl is no longer used to preform that function. I also have to figure out what else might be affected by other changes. This is basicly starting from scratch so for the release canidate you'll most likely have to build it. I should have everything sorted by the time the actual release is ready.
Regards,
Corey
Regards,
Corey
Just an FYI,
Everything so far is going good with the new RPM generation and the database stuff I got straitened out allot quicker than I had thought. I do how ever have some more work to do.
Phil, What all is affected by zm.conf in the build process?
I'll need to eliminate any dependency on it in the build process.
Regards,
Corey
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
Okay, Perfect...
The only thing I have found is that I just have to strip the create and use from the sql file so no problem there
The only thing I haven't yet looked into is, and I don't know if this was an over site but your instructions mention nothing of loading the database. I assume that this stays the same as before?
At least thats how I'm treating it in the spec file and I'm sure the question will arise soon anyway for a new user
I'll be reworking the rest of the scripts after I go get some sleep. All else is going good and should be testing tomorrow
Regards,
Corey
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
