Further to my post in the Hardware Compatibility forum -> http://www.zoneminder.com/forums/viewtopic.php?t=5451 I have now finished the script and uploaded it for your viewing pleasure (if you'll pardon the pun).
The script can be found here -> http://www.hunter13.com/zoneminder/zmcontrol-ncs370.txt
Download it. Rename it to zmcontrol-ncs370.pl and place it in the same directory as the other ZoneMinder scripts (probably /usr/local/bin). Then add your camera and set up a Control Type to point to this script. Screenshots of my configuration can be found at http://www.hunter13.com/zoneminder/ncs370w.html If there's enough interest I'll write up some proper instructions.
In it's current form the camera can be moved left/right, up/down and diagonally. The camera doesn't have native diagonal movement so I've bodged it by sending a left/right followed by an up/down command as appropriate. In addition, the Home position and the 24 preset positions can be moved to. There's no support for setting presets so you'll have to do that via the native camera control webpage or wait for me to implement it.
Neu-Fusion NCS370(W) pan/tilt control script
- zoneminder
- Site Admin
- Contact:
Here you go:
insert into Controls values (6,'NCS370','Remote','zmcontrol-ncs370.pl',0,0,0,0,0,0,0,0,NULL,NULL,NULL,NULL,0,NULL,NULL,0,0,0,0,0
,NULL,NULL,NULL,NULL,0,NULL,NULL,0,0,0,0,0,NULL,NULL,NULL,NULL,0,NULL,NULL,0,0,0,0,0,NULL,NULL,NULL,NULL,0,NULL,NULL,0,0,0,0,0,NULL,
NULL,NULL,NULL,0,NULL,NULL,1,24,1,0,1,1,0,0,0,1,1,NULL,NULL,NULL,NULL,0,NULL,NULL,0,NULL,1,NULL,NULL,NULL,NULL,0,NULL,NULL,0,NULL,0,0
This is a copy of the panasonic entry from zmschema.sql with appropriate changes.
- zoneminder
- Site Admin
- Contact:
