Problems starting zm
hi,
I'm trying to start ZoneMinder but I receive this error, what could it be?
Distribution: SUSE SLES 9
perl v5.8.3 built for x86_64-linux-thread-multi
kernel 2.6.5-7.244-smp
Architecture x86_64
Thanks,
Luca
linux-server:~/ZoneMinder-1.22.0/scripts # ./zm start
Starting ZoneMinder: Bareword "ZM_SHM_KEY" not allowed while "strict subs" in use at /usr/lib/perl5/site_perl/5.8.3/ZoneMinder/SharedMem.pm line 156.
Compilation failed in require at /usr/lib/perl5/site_perl/5.8.3/ZoneMinder.pm line 36.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.3/ZoneMinder.pm line 36.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 45.
./zm: line 17: echo_failure: command not found
Architecture x86_64
Thanks,
Luca
- zoneminder
- Site Admin
- Contact:
I have the same problem, but i have mysql running, and the database created, at first i did receive an error that it could not connect to the database. After setting the correct values in zm.conf, that error went away, but the other errors remained like in the first posting ...zoneminder wrote:Are you using version 1.22.0? If so then it means you haven't created/loaded the database.
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
Bareword "ZM_SHM_KEY" not allowed while "strict subs" in use at /usr/lib/perl5/site_perl/5.8.7/ZoneMinder/SharedMem.pm line 221.
Compilation failed in require at /usr/lib/perl5/site_perl/5.8.7/ZoneMinder.pm line 36.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.8.7/ZoneMinder.pm line 36.
My system is a gentoo linux.
- zoneminder
- Site Admin
- Contact:
Thanks.
Can you create a simple perl script as follows
Call it what you want and then run it, by typing 'perl <yourscript>.pl' either as root or in your zm directory (with a valid zm.conf in), if not both. Please post what you get.
#!/usr/bin/perl -w
use strict;
$| = 1;
use ZoneMinder::Config qw/:all/;
print ZM_SHM_KEY."\n";
Phil
- zoneminder
- Site Admin
- Contact:
Can you confirm that if you do
that you get a row of data out?
mysql -u<your db user> -p<your db pass> <your db>
select * from Config where Name = "ZM_SHM_KEY";
quit;
Phil
- zoneminder
- Site Admin
- Contact:
Also, can you change the line in the perl script that says
to say
and see what that does.
print &ZM_SHM_KEY."\n";
Phil
- zoneminder
- Site Admin
- Contact:
