I had a lot of problems with trying to build and install under Fedora 3 (both with the database as others have pointed out and with the perl scripts - something wrong with the constants, some were not defined etc). Itried to fix the problems by hand but must have missed something because I do not manage to make zm work.
Now I would like to uninstall what "make install" did and try a RPM install but what exactly do I need to remove from my system to be back were I started?
I would also apreciate a good link to RPM for 1.22 or 1.21 for FC3. I tried some that I found on the forum but it did not work...
- Trist
How to ininstall?
corey is your man if you look in the contribs for cordels distro that will give you (the only i think) rpm's for fc3. I can testify myself that they work as im typing this from my zm server fc3 using cordel's rpm'm
James
James
James Wilson
- zoneminder
- Site Admin
- Contact:
