HTML typo causing a MySQL error....
tgutwin
Post by tgutwin »
In the new user dialog there is a typo "'" character inside the
MonitorIds input field
<input type="text" name="new_user['MonitorIds]"
see the ' char right before the word MonitorIds
It causes the following error when the form is submitted.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '\'MonitorIds = '1,2'' at line 1
You can recreate the error by doing the following:
open up the 'users' tab in options dialog then
click the 'add new user'
view the source and scroll right to the bottom....
That'll be an easy fix.
zoneminder
Site Admin
Post by zoneminder »
Thanks. I've updated it ready for the next release.
Phil
