Page 1 of 1
Cambozola and streaming video help
Posted: Sat Jan 14, 2006 3:35 pm
by rlefeve
I have a question about the configuration of cambozola.
I can see that the cambozola.jar file is sitting in the /usr/lib/zm/html directory.
I also understand that I need to have java installed on my Windows PC (IE6) that I would like to view my cameras on.
My question is how do I configure my browser to use cambozola to view the streaming video?
I am using an AXIS 205. And the streaming video I get from ZM seem to be a refresh of a still every 5 to 10 seconds.
Posted: Sat Jan 14, 2006 8:57 pm
by cordel
If you have zm configured to use cambozola properly and java is available on the client machine it should work.
Make sure you have options -> tools -> ZM_OPT_CAMBOZOLA checked and ZM_PATH_CAMBOZOLA should be the path relative to your web root so your path should be just cambozola.jar and nothing else.
You may have to adjust the client security settings to allow the script to run.
Regards,
Corey
Posted: Sat Jan 14, 2006 9:14 pm
by rlefeve
Ok, from what I am getting. It looks as though the java on my windows box is all that is needed from a client perspective.
Then it is probably the fact that my zm server is running on 466Mhz Celeron with 380Meg or RAM.
