mysql 5 use ?
phaksp
mysql 5 use ?
Post by phaksp »
is it possible to use mysql 5 with zone minder 1.22.X ?
Regards,
Sophak
Debian stable 2.6.8-4-k7 kernel - logitech pro 4000 X 3 - zoneminder 1.21.3
Learning Php / Mysql / Java /
cordel
Post by cordel »
I believe it should work but, I have not tried myself nor am I aware of anyone that has.
I would suggest making a test system and build it on mysql 5 and see if it works before commiting anything to it. If I get some time I can take a wack at it but it will be a while.
Corey
majik-br
Post by majik-br »
I was going nuts with some php problems on my new SuSE 10.0 installation and decided to compile latest versions for everything, so I'm running zm on:
Apache 2.2.0
PHP 5.1.2
MySQL 5.0.18
so far no problems whatsoever. Am I just lucky? :wink:
[]s
phaksp
Post by phaksp »
thanks for the feedback :]
Regards,
Sophak
