I installed ffmpeg-devel and all its dependencies from RPM packages. It was a bit of a pain, but most of them were available from http://dag.wieers.com/packages/. libtheora-devel came from CentOS itself.
After rerunning ./configure I reran zmconfig.pl. I got a bit stuck where it was asking for additional input options - it wouldn't let me leave this blank. So I gave an arbitary one:
Additional input options to ffmpeg (string) [] :
Invalid input, please re-enter or type '?' for help.
Additional input options to ffmpeg (string) [] : -author brian
Now the 'export' link is unchanged but I have a new 'video' link. Unfortunately it fails:
Video Generation Parameters Close
Video Format [ mpg ]
Frame Rate [ real ]
Video Size [ actual ]
Overwrite Existing [ ]
Video Generation Failed! << this displayed in red
$ ls -l /var/www/html/zm/events/1/911/ | grep -v \\.jpg
total 25456
-rw-r--r-- 1 apache apache 0 Jan 17 15:11 Event-911-r1-s1.mpg
-rw-r--r-- 1 apache apache 0 Jan 17 15:11 ffmpeg.log
Apache error logs just have a load of
jpegtopnm: WRITING PPM FILE
Is there anything else I should be checking to try to find out why it's not working? Clearly I'd like to see the command line passed to ffmpeg, and its error output.
Also, it's not clear to me that the ffmpeg package I've installed was compiled with sufficient features, although it seems to be pretty comprehensive. Does it need to be compiled with plain jpeg image support? Here's the output of ffmpeg -formats.
[candlerb@webcam ~]$ rpm -qa | grep ffmpeg
ffmpeg-0.4.9-0.3.20051207.2.el4.rf
ffmpeg-libpostproc-0.4.9-0.3.20051207.2.el4.rf
ffmpeg-devel-0.4.9-0.3.20051207.2.el4.rf
[candlerb@webcam ~]$ ffmpeg -formats
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --prefix=/usr --libdir=/usr/lib --mandir=/usr/share/man --enable-mp3lame --enable-libogg --enable-vorbis --enable-theora --enable-faad --enable-faac --enable-libgsm --enable-xvid --enable-x264 --enable-a52 --enable-a52bin --enable-dts --enable-pp --enable-shared-pp --enable-shared --enable-pthreads --enable-gpl --disable-opts --disable-strip
built on Jan 6 2006 21:05:55, gcc: 3.4.4 20050721 (Red Hat 3.4.4-2)
File formats:
E 3g2 3gp2 format
E 3gp 3gp format
D 4xm 4X Technologies format
D RoQ Id RoQ format
DE ac3 raw ac3
DE alaw pcm A law format
DE asf asf format
E asf_stream asf format
DE au SUN AU Format
DE audio_device audio grab and output
DE avi avi format
E crc crc testing format
D daud D-Cinema audio format
D dts raw dts
DE dv DV video format
D dv1394 dv1394 A/V grab
E dvd MPEG2 PS format (DVD VOB)
D ea Electronic Arts Multimedia Format
DE ffm ffm format
D film_cpk Sega FILM/CPK format
D flic FLI/FLC/FLX animation format
DE flv flv format
E framecrc framecrc testing format
DE gif GIF Animation
DE h261 raw h261
DE h263 raw h263
DE h264 raw H264 video format
D idcin Id CIN format
DE image image sequence
DE image2 image2 sequence
DE image2pipe piped image2 sequence
DE imagepipe piped image sequence
D ingenient Ingenient MJPEG
D ipmovie Interplay MVE format
DE m4v raw MPEG4 video format
D matroska Matroska file format
DE mjpeg MJPEG video
DE mmf mmf format
E mov mov format
D mov,mp4,m4a,3gp,3g2 QuickTime/MPEG4 format
E mp2 MPEG audio layer 2
DE mp3 MPEG audio layer 3
E mp4 mp4 format
DE mpeg MPEG1 System format
E mpeg1video MPEG video
E mpeg2video MPEG2 video
DE mpegts MPEG2 transport stream format
D mpegvideo MPEG video
E mpjpeg Mime multipart JPEG format
DE mulaw pcm mu law format
D nsv NullSoft Video format
E null null video format
DE nut nut format
DE ogg Ogg Vorbis
E psp psp mp4 format
D psxstr Sony Playstation STR format
DE rawvideo raw video format
D redir Redirector format
DE rm rm format
E rtp RTP output format
D rtsp RTSP input format
DE s16be pcm signed 16 bit big endian format
DE s16le pcm signed 16 bit little endian format
DE s8 pcm signed 8 bit format
D sdp SDP
D shn raw shorten
D sol Sierra SOL Format
E svcd MPEG2 PS format (VOB)
DE swf Flash format
DE u16be pcm unsigned 16 bit big endian format
DE u16le pcm unsigned 16 bit little endian format
DE u8 pcm unsigned 8 bit format
E vcd MPEG1 System format (VCD)
D video4linux video grab
D vmd Sierra VMD format
E vob MPEG2 PS format (VOB)
DE wav wav format
D wc3movie Wing Commander III movie format
D wsaud Westwood Studios audio format
D wsvqa Westwood Studios VQA format
DE yuv4mpegpipe YUV4MPEG pipe format
Image formats (filename extensions, if any, follow):
DE gif gif
Codecs:
D V 4xm
D V D 8bps
DEA aac
D V D aasc
DEA ac3
DEA adpcm_4xm
DEA adpcm_adx
DEA adpcm_ct
DEA adpcm_ea
DEA adpcm_ima_dk3
DEA adpcm_ima_dk4
DEA adpcm_ima_qt
DEA adpcm_ima_smjpeg
DEA adpcm_ima_wav
DEA adpcm_ima_ws
DEA adpcm_ms
DEA adpcm_swf
DEA adpcm_xa
DEA adpcm_yamaha
D A alac
DEV D asv1
DEV D asv2
D V bmp
D V D camtasia
D V D cinepak
D V D cljr
D V D cyuv
D A dts
DES dvbsub
DES dvdsub
DEV D dvvideo
DEV D ffv1
DEVSD ffvhuff
D A flac
D V D flic
DEVSD flv
D V D fraps
DEA g726
DEA gsm
DEV D h261
DEVSDT h263
D VSD h263i
EV h263p
DEV DT h264
DEVSD huffyuv
D V D idcinvideo
D V D indeo2
D V indeo3
D A interplay_dpcm
D V D interplayvideo
EV ljpeg
D V D loco
D A mace3
D A mace6
D V D mdec
DEV D mjpeg
D V D mjpegb
DEA mp2
DEA mp3
D A mp3adu
D A mp3on4
DEVSDT mpeg1video
DEVSDT mpeg2video
DEVSDT mpeg4
D A mpeg4aac
D VSDT mpegvideo
DEVSD msmpeg4
DEVSD msmpeg4v1
DEVSD msmpeg4v2
D V D msrle
D V D msvideo1
D V D mszh
DEV pam
DEV pbm
DEA pcm_alaw
DEA pcm_mulaw
DEA pcm_s16be
DEA pcm_s16le
DEA pcm_s24be
DEA pcm_s24daud
DEA pcm_s24le
DEA pcm_s32be
DEA pcm_s32le
DEA pcm_s8
DEA pcm_u16be
DEA pcm_u16le
DEA pcm_u24be
DEA pcm_u24le
DEA pcm_u32be
DEA pcm_u32le
DEA pcm_u8
DEV pgm
DEV pgmyuv
DEV png
DEV ppm
D A qdm2
D V D qdraw
D V D qpeg
D V D qtrle
DEV rawvideo
D A real_144
D A real_288
D A roq_dpcm
D V D roqvideo
D V D rpza
DEV D rv10
DEV D rv20
D A shorten
D V D smc
DEV snow
D A sol_dpcm
DEA sonic
EA sonicls
D V D sp5x
DEV D svq1
D VSD svq3
D V theora
D V D truemotion1
D V D truemotion2
D V D ultimotion
D V vc9
D V D vcr1
D A vmdaudio
D V D vmdvideo
DEA vorbis
D V vp3
D V D vqavideo
D A wmav1
D A wmav2
DEVSD wmv1
DEVSD wmv2
D V wmv3
D V D wnv1
D A ws_snd1
D A xan_dpcm
D V D xan_wc3
D V D xl
EV xvid
DEV D zlib
Supported file protocols:
file: pipe: udp: rtp: tcp: http:
Frame size, frame rate abbreviations:
ntsc pal qntsc qpal sntsc spal film ntsc-film sqcif qcif cif 4cif
Motion estimation methods:
zero(fastest) full(slowest) log phods epzs(default) x1
Note, the names of encoders and decoders dont always match, so there are
several cases where the above table shows encoder only or decoder only entries
even though both encoding and decoding are supported for example, the h263
decoder corresponds to the h263 and h263p encoders, for file formats its even
worse
Value: ffmpeg
Description: Is there an (optional) mpeg video encoder installed
Value: /usr/local/bin/mpeg_encode
Description: Path to (optional) Berkeley mpeg encoder
Value: /usr/bin/ffmpeg
Description: Path to (optional) ffmpeg mpeg encoder
Value: -author brian
Description: Additional input options to ffmpeg
Value: -r 5
Description: Additional output options to ffmpeg
Value: mpg* mpeg wmv avi mov 3gp**
Description: Formats to allow for ffmpeg video generation
Cheers, Brian.
