dcs-900 not working..
hey guys,
i am having troubles getting my dlink dcs-900 cam to work with zoneminder 1.21.3 running on ubuntu server 5.10. I installed with the debian package, and my current set up is as follows:
Remote Host Name: http://ip/
Remote Host Port: 80
Remote Host Path: /video.cgi
Capture Width (pixels): 320
Capture Height (pixels) : 240
Orientation: Normal
all i am getting at the moment is a black screen when trying to view it. any ideas that could help me get this thing running would be much appreciated.
jared.
Orientation: Normal
jared.
- zoneminder
- Site Admin
- Contact:
Re: dcs-900 not working..
This is just a host 'name'' (or ip) and not a url and as such doesn't need a protocol specifier. So just use 'ip' instead.dbw wrote: Remote Host Name: http://ip/
Phil
- zoneminder
- Site Admin
- Contact:
hi, thanks again for your reply..
here is the contents of the log files:
zmwatch.log:
Can't get shared memory id '2053971971' : No such file or directory
zmdc.log:
tarting pending process, zmc -d 0
'zmc -d 0' started at 06/01/23 10:27:20
'zmc -d 0' starting at 06/01/23 10:27:20, pid = 11143
'zmc -d 0' crashed at 06/01/23 10:27:20, exit status 255
Starting pending process, zmc -m 1
'zmc -m 1' started at 06/01/23 10:27:42
'zmc -m 1' starting at 06/01/23 10:27:42, pid = 11147
'zmc -m 1' crashed at 06/01/23 10:27:54, exit status 255
let me know if you want more information..
jared.
zmwatch.log:
zmdc.log:
jared.
just done a search on dcs-900 and noticed another post that doesnt have the leading slash in the path? maybe worth a go?
James Wilson
the only thing i can suggest is do you know for sure that your zm bix is working, ie have you had any images ever from any type of input. I would also suggest turning reg exps on in settings but i doubt it will help as it appears a problem getting images out of your cam into zm
James Wilson
- zoneminder
- Site Admin
- Contact:
There are a couple of people here that genuinly make me fall over with laughter from the quotes.the quality is so useless that you'd hardly notice the difference between an image and a black screen
D-link seem bad that ever there routers are poor. I would stick em all in a box with maxtor disks oh and cyrix processors
James Wilson
okay guys..thanks heaps for your suggestions..
ive checked the messages log, and nothing really stands out. Ive tried entering remote host path as VIDEO.CGI, and no luck.
now im not 100% sure that this zm box is working. i havent had any images or video produced from any sort of input. in regards to your suggestion of turning on reg exps - im really new to linux, and wouldnt have the slightest idea on how to do this sorry to be a pain guys..the only thing i can suggest is do you know for sure that your zm bix is working, ie have you had any images ever from any type of input. I would also suggest turning reg exps on in settings but i doubt it will help as it appears a problem getting images out of your cam into zm
its a zm config thing, basically uses a slightly different way to retrieve images from the cam.
if you go to options, under network you will find a xheckbox called use reg exp. Turn it on. Also go back to your original config, with the leading/.
Can you also load the image in firefox, right click and report all the properties show ie path, image size etc
warm regards
warm regards
James Wilson
thanks james.
I have tried the regexps setting in zm, however i am still not having any luck at all. at the moment i am getting nothing coming up when i attempt to view the video, it just sits there aparrantly "transferring data". After a few minutes i just get a torn image icon. If i press on the stills link i just get a black screen, no image.
when viewing http://192.168.1.202/image.jpg link, i get a still shot off the camera. i go to the properties of the image, and i get the following:
Width: 320px
Height: 240px
Size of File: 6.06 KB (6204 bytes)
Alternate Text: The image “http://192.168.1.202/image.jpg” cannot be displayed, because it contains errors.
thanks again,
jared.
Width: 320px
Height: 240px
thanks again,
jared.
- zoneminder
- Site Admin
- Contact:
