Page 1 of 1
How im supposed to use Raw Streaming ?
Posted: Fri Jan 20, 2006 10:02 am
by victor_diago
Hi all and Phil,
Im starting to test 1.22 right today, and i would like to understand how can i use the raw streaming format.
i mena, mplayer can read it ? what is the command line arguments for zms ?
Thanks for now
Victor Diago
Posted: Fri Jan 20, 2006 10:12 am
by zoneminder
The raw streaming mode is not really meant for streaming to players like WMP. It was put in to reduce the overhead of streaming to James' gui viewers. That's not to say that it wouldn't work with any viewer that could handle the format but it's not a standard format supported by anything else as far as I'm aware.
Posted: Fri Jan 20, 2006 11:48 am
by victor_diago
Hmm ive got it.
But what is the format ? RGB ?
Victor Diago
Posted: Fri Jan 20, 2006 12:42 pm
by zoneminder
Yes, straight out of shared memory WxHxD bytes in RGB format identified by image/x-rgb mime type.
Posted: Fri Jan 20, 2006 6:12 pm
by jameswilson
I will start work on this when i get round to upgrading my 'office' zm box to 1.22.x
Posted: Fri Jan 20, 2006 9:52 pm
by victor_diago
Wooow.
I can read two things :
1 - Cpu less intensive
2 - No more Delay problems.
am i right ?
i see that mplayer deals with raw rgb data, will try it.
Thanks for now.
Victor Diago
Posted: Fri Jan 20, 2006 10:20 pm
by jameswilson
Yes it will be less cpu intensive but i doubt it will help the delay issues of mplayer as the delay is not due to zm, but the chosen media player. I plan to use it on zm4ms and the linux version.
Posted: Fri Jan 20, 2006 11:27 pm
by victor_diago
i hope it will make any difference.
ive tested mplayer, vlc, WindowsMediaPlayer, flash player plugin and a lot of others, local and remote.
All them did just the SAME way.
So, im anxious to try it.
Thanks For now
Victor Diago
Posted: Sat Jan 21, 2006 12:10 pm
by zoneminder
Raw streaming uses a lot more network bandwidth than other streams so if the lag was related to networking then it's only going to make it worse! However as jpeg streaming doesn't lag I think networking issues are not why plugins etc all lag.
The only real solution to the lagging is to get video streaming to use rtp and multicasting I think. Once I've done a bit more research into this I will try and add it.
