It's my custom ebuild, an alternative to the one in the main portage tree, and I don't use ffmpeg, so it may need tweaks if it's to work with ffmpeg. Also, note that it is customised, and it isn't in an install and run out of the box state. To make some use of it, fetch the file, and then do:
# cd /usr/local/portage # or wherever you put your *local* portage tree
# tar zvxf /path/to/zm-1.22.0-portage.tgz
# cd www-misc/zoneminder
# ls
-rw-r--r-- rick/users 2531 2006-01-26 22:50:57 www-misc/zoneminder/zoneminder-1.22.0.ebuild
-rw-r--r-- rick/users 16425 2006-01-22 20:20:48 www-misc/zoneminder/files/zm-1.22.0-scripts.patch
-rw-r--r-- rick/users 6522 2006-01-19 08:31:14 www-misc/zoneminder/files/zm-1.22.0-security.patch
-rw-r--r-- rick/users 2628 2006-01-19 08:31:14 www-misc/zoneminder/files/zm-1.22.0-zone.patch
# ebuild zoneminder-1.22.0.ebuild digest
It will put:
- executable stuff into /usr/bin
- the init script into /etc/init.d
- config stuff into /etc/zm
- logs into /var/log/zm
- runstate stuff into /var/run/zm
- web stuff into ~apache/zm
- CGI stuff into ~apache/zm/bin (I probably ought to move this...)
- documentation into /usr/share/doc/zoneminder-1.22.0
Also, note that the destination for the web stuff is determined by the home directory assigned to the apache user, so if you want to move this from the default /var/www/localhost/htdocs then modify /etc/passwd before running emerge. While you're there, ZoneMinder needs to have apache able to run a normal shell, so you'll have to change the default /bin/false to something useful like /bin/bash.
You'll need to edit /etc/zm/zm.conf to make sure things like the ZM_DB_USER and ZM_DB_PASS are sane.
You'll need to do some tweaks to your apache config too. If ~apache were at /www you'd need something a bit like this:
Alias /zm/ /www/zm/
<Directory /www/zm>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
ScriptAlias /cgi-bin/ /www/zm/bin/
<Directory /www/zm/bin>
AllowOverride None
Options ExecCGI
Order allow,deny
Allow from all
</Directory>
/usr/bin/zmupdate.pl -version=1.21.? --user=root --pass=?????
/etc/init.d/zm start
rc-update -a default zm
