Tuning ZM for Modect
tim@pcs-alaska.com
Post by tim@pcs-alaska.com »
Last week I uninstalled my 1.21 version of ZM and install ZM 1.22.
I'm running into a few configuration problems:
1. I'm trying to run zmu against my remote cameras but that is failing because I don't know how to run it against my ip:port# of the cameras.
Here is my setup:
Camera 1 is at 192.168.1.1:8001
Camera 2 is at 192.168.1.2:8002
Camera 3 is at 192.168.1.3:8003
How should my syntax work with zmu? I see it wants a file or directory. Do I somehow map my remote cameras to a file or dir?
2. I created a monitor I want to now delete. Problem is I can't delete it? The browser refreshes after I click delete and the monitor is still present.
3. Is there a quick way to delete all events and start fresh?
Thank you,
Tim Jordan
ZoneMinder 1.22
Debian Sarge
P4 1.7Ghz, 512MB, 160GB HD
(3) Panisonic KX-HCM10 Network Cameras
acrid
Post by acrid »
1) did you enable ip-cam support in the options? there is no need for mapping the cameras...
2) http://www.zoneminder.com/forums/viewtopic.php?t=5567
3) delete the events from the db or the filesystem, zmaudit.pl will do a clean up
cheers
$> man woman
$> Segmentation fault (core dumped)
