Problem with zmc (segfault)
Posted: Tue Jan 31, 2006 3:02 pm
Hi all,
I'm new to ZoneMinder and installed the actual version for the first time yesterday. Now I have the following problem.
When starting "zmc -d /dev/video0" it crashes. A backtrace with gdb shows the following:
After commenting out this in src/zm_zone.cpp line 873 zmc seems to work without problems but that should not be the final solution
Has anyone an idea how to solve this issue?
Greetings Michael
Program received signal SIGSEGV, Segmentation fault.
0x402fd00e in _int_malloc () from /lib/i686/libc.so.6
#0 0x402fd00e in _int_malloc () from /lib/i686/libc.so.6
#1 0x402fc06c in malloc () from /lib/i686/libc.so.6
#2 0x4023369e in operator new(unsigned) () from /usr/lib/libstdc++.so.5
#3 0x402337cd in operator new[](unsigned) () from /usr/lib/libstdc++.so.5
#4 0x0804e0c6 in Polygon (this=0xbffff0e0, p_n_coords=2, p_coords=0xde2d6c8)
at zm_poly.cpp:55
#5 0x08056ffc in Zone::ParsePolygonString(char const*, Polygon&) (
poly_string=0xbffff0e0 "\002", polygon=@0xbffff1d0) at zm_zone.cpp:768
#6 0x08057617 in Zone::Load(Monitor*, Zone**&) (monitor=0xde079f0,
zones=@0xbffff2ac) at zm_zone.cpp:873
#7 0x08062b04 in Monitor::LoadLocalMonitors(char const*, Monitor**&, Monitor::Purpose) (device=0x403b8a74 "Ð5ã\rÐÖâ\r", monitors=@0xbffff338, purpose=CAPTURE)
at zm_monitor.cpp:1253
#8 0x0804bc07 in main (argc=-1073744130, argv=0xbffff574) at zmc.cpp:161
/*if ( !ParsePolygonString( Coords, polygon ) )
continue;
Greetings Michael
