There is a little bug in message corp, missing caracter " at the end of message, generate log in zmdc.log :
Use of uninitialized value in pattern match (m//) at /usr/lib/zm/bin/zmfilter.pl line 755.
Use of uninitialized value in pattern match (m//) at /usr/lib/zm/bin/zmfilter.pl line 770.
Use of uninitialized value in substitution (s///) at /usr/lib/zm/bin/zmfilter.pl line 795.
Use of uninitialized value in substitution (s///) at /usr/lib/zm/bin/zmfilter.pl line 796.
line 755-860
patch zm_create.sql.in and ConfigAdmin.pm.in correct here :
Edit at 4:52 : sorry, i MODIF F**** caracter ", change '" by "' in ConfidAdmin : AARRRRRRRGGGHH !!!!!!
diff -ru ZoneMinder-1.22.0.ori/db/zm_create.sql.in ZoneMinder-1.22.0/db/zm_create.sql.in
--- ZoneMinder-1.22.0.ori/db/zm_create.sql.in 2006-01-18 10:37:32.000000000 +0100
+++ ZoneMinder-1.22.0/db/zm_create.sql.in 2006-01-31 18:10:18.000000000 +0100
@@ -612,7 +612,7 @@
This alarm was matched by the %FN% filter and can be viewed at %EPS%
-ZoneMinder', Type = 'text', DefaultValue = 'subject = \"ZoneMinder: Alarm - %MN%-%EI% (%ESM% - %ESA% %EFA%)\"
+ZoneMinder\"', Type = 'text', DefaultValue = 'subject = \"ZoneMinder: Alarm - %MN%-%EI% (%ESM% - %ESA% %EFA%)\"
body = \"
@@ -628,12 +628,12 @@
-ZoneMinder', Hint = 'free text', Pattern = '(?-xism:^(.+)$)', Format = ' $1 ', Prompt = 'The text of the email used to send matching event details', Help = 'This option is used to define the content of the email that is sent for any events that match the appropriate filters.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_EMAIL=1';
+ZoneMinder\"', Hint = 'free text', Pattern = '(?-xism:^(.+)$)', Format = ' $1 ', Prompt = 'The text of the email used to send matching event details', Help = 'This option is used to define the content of the email that is sent for any events that match the appropriate filters.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_EMAIL=1';
insert into Config set Id = 86, Name = 'ZM_OPT_MESSAGE', Value = '0', Type = 'boolean', DefaultValue = 'no', Hint = 'yes|no', Pattern = '(?i-xsm:^([yn]))', Format = ' ($1 =~ /^y/) ? \"yes\" : \"no\" ', Prompt = 'Should ZoneMinder message you with details of events that match corresponding filters', Help = 'In ZoneMinder you can create event filters that specify whether events that match certain criteria should have their details sent to you at a designated short message email address. This will allow you to be notified of events as soon as they occur. This option specifies whether this functionality should be available. The email created by this option will be brief and is intended to be sent to an SMS gateway or a minimal mail reader such as a mobile device or phone rather than a regular email reader.', Category = 'mail', Readonly = '0', Requires = '';
insert into Config set Id = 87, Name = 'ZM_MESSAGE_ADDRESS', Value = '', Type = 'string', DefaultValue = '', Hint = 'your.name@your.domain', Pattern = '(?-xism:^([a-zA-Z0-9_.-]+)\@([a-zA-Z0-9_.-]+)$)', Format = ' $1\@$2 ', Prompt = 'The email address to send matching event details to', Help = 'This option is used to define the short message email address that any events that match the appropriate filters will be sent to.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_MESSAGE=1';
insert into Config set Id = 88, Name = 'ZM_MESSAGE_TEXT', Value = 'subject = \"ZoneMinder: Alarm - %MN%-%EI%\"
-body = \"ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score.', Type = 'text', DefaultValue = 'subject = \"ZoneMinder: Alarm - %MN%-%EI%\"
-body = \"ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score.', Hint = 'free text', Pattern = '(?-xism:^(.+)$)', Format = ' $1 ', Prompt = 'The text of the message used to send matching event details', Help = 'This option is used to define the content of the message that is sent for any events that match the appropriate filters.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_MESSAGE=1';
+body = \"ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score.\"', Type = 'text', DefaultValue = 'subject = \"ZoneMinder: Alarm - %MN%-%EI%\"
+body = \"ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score.\"', Hint = 'free text', Pattern = '(?-xism:^(.+)$)', Format = ' $1 ', Prompt = 'The text of the message used to send matching event details', Help = 'This option is used to define the content of the message that is sent for any events that match the appropriate filters.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_MESSAGE=1';
insert into Config set Id = 89, Name = 'ZM_NEW_MAIL_MODULES', Value = '0', Type = 'boolean', DefaultValue = 'no', Hint = 'yes|no', Pattern = '(?i-xsm:^([yn]))', Format = ' ($1 =~ /^y/) ? \"yes\" : \"no\" ', Prompt = 'Whether to use a newer perl method to send emails', Help = 'Traditionally ZoneMinder has used the MIME::Entity perl module to construct and send notification emails and messages. Some people have reported problems with this module not being present at all or flexible enough for their needs. If you are one of those people this option allows you to select a new mailing method using MIME::Lite and Net::SMTP instead. This method was contributed by Ross Melin and should work for everyone but has not been extensively tested so currently is not selected by default.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_EMAIL=1;ZM_OPT_MESSAGE=1';
insert into Config set Id = 90, Name = 'ZM_EMAIL_HOST', Value = 'localhost', Type = 'string', DefaultValue = 'localhost', Hint = 'host.your.domain', Pattern = '(?-xism:^([a-zA-Z0-9_.-]+)$)', Format = ' $1 ', Prompt = 'The host address of your SMTP mail server', Help = 'If you have chosen SMTP as the method by which to send notification emails or messages then this option allows you to choose which SMTP server to use to send them. The default of localhost may work if you have the sendmail, exim or a similar daemon running however you may wish to enter your ISP\'s SMTP mail server here.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_EMAIL=1;ZM_OPT_MESSAGE=1';
insert into Config set Id = 91, Name = 'ZM_FROM_EMAIL', Value = '', Type = 'string', DefaultValue = '', Hint = 'your.name@your.domain', Pattern = '(?-xism:^([a-zA-Z0-9_.-]+)\@([a-zA-Z0-9_.-]+)$)', Format = ' $1\@$2 ', Prompt = 'The email address you wish your event notifications to originate from', Help = 'The emails or messages that will be sent to you informing you of events can appear to come from a designated email address to help you with mail filtering etc. An address of something like ZoneMinder@your.domain is recommended.', Category = 'mail', Readonly = '0', Requires = 'ZM_OPT_EMAIL=1;ZM_OPT_MESSAGE=1';
diff -ru ZoneMinder-1.22.0.ori/scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm.in ZoneMinder-1.22.0/scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm.in
--- ZoneMinder-1.22.0.ori/scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm.in 2006-01-17 18:07:08.000000000 +0100
+++ ZoneMinder-1.22.0/scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm.in 2006-01-31 18:06:41.000000000 +0100
@@ -831,7 +831,7 @@
-ZoneMinder',
+ZoneMinder"',
description => "The text of the email used to send matching event details",
requires => [ { name => "ZM_OPT_EMAIL", value => "yes" } ],
help => "This option is used to define the content of the email that is sent for any events that match the appropriate filters.",
@@ -858,7 +858,7 @@
name => "ZM_MESSAGE_TEXT",
default => 'subject = "ZoneMinder: Alarm - %MN%-%EI%"
-body = "ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score.',
+body = "ZM alarm detected - %ED% secs, %EF%/%EFA% frames, t%EST%/m%ESM%/a%ESA% score."',
description => "The text of the message used to send matching event details",
requires => [ { name => "ZM_OPT_MESSAGE", value => "yes" } ],
help => "This option is used to define the content of the message that is sent for any events that match the appropriate filters.",
Have a nice day and Say it with flowers!
Chaapai..
