Page 1 of 1
ZoneMinder + XBMC (XBOX)
Posted: Sun Feb 05, 2006 6:33 pm
by mlrtime3
Well I just got zoneminder up today, and after seeing these two threads:
http://www.zoneminder.com/forums/viewtopic.php?t=5456
http://www.zoneminder.com/forums/viewtopic.php?t=3780
I was able to easily setup a live video stream to my xbmc install which is hooked up to my 57" HDTV. I must say the quality is pretty good.
What I did was install URLPaster from http://www.xbmcscripts.com/
http://www.xbmcscripts.com/modules/mod_ ... itstart=30
The instructions for the urlpaster program are straight forward. I loaded xbmc, installed the urlpaster python scripts and launched the main URLPaster.py.
Then with the pc app I pasted the mplayer url
http://192.168.0.5/cgi-bin/nph-zms?mode ... format=asf
You can change your ip/monitor.
This basically verifies that it is easy to stream the feed to xbmc. I'll try working on a python script that has config settings to load this automatically without the url paster.
-mlr
Posted: Mon Feb 06, 2006 10:53 pm
by zoneminder
Excellent, thanks for posting to let us know.
Posted: Fri Aug 11, 2006 7:13 am
by KaZeR
Wow exactly what i came looking for today.
If you need some help or someone to test your script, let me know!
Posted: Sat Aug 29, 2009 8:31 pm
by ThomasNovin
Hello!
Did you ever get this working? Right now the URL paster script is inaccessible because xbmcscripts.com is down (has been for a long time).
Posted: Sun Nov 29, 2009 10:03 am
by habichtha
Do the xbox live cards that you buy at walmart work for the old.original xbox? I have an original xbox, and walmart sells xbox live cards for 360s. Will these work for my old xbox?
_________________
external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com
Posted: Sun Jan 24, 2010 7:16 pm
by orlandold
I wish to get my IP cameras through their internal web server feed or through zoneminder, streaming to a XBMC or even a BOXEE setup ...
It seems that through URLPASTER on xbmc will do the job... I am unable to locate URLPASTER.. the xbmcscripts site has been down for a while
please let me know where to get it... or even if you have any suggestions on how to get the feeds from the cameras to be shown on a mac mini connected to a TV, I will appreciate.
(XBMC, BOXEE, FrontRow ????? )
thanks,
