I have tried to install zm-1.21.4 on Mandriva 2006 without success so far.
I URPMI mysql packages MYSQL MYSQL-client libmysql4-devel which were missing.
When I start zmpkg.pl and connect to browser on localhost/zm i see a blank page with no content ( and no error messages either).
Another file I created for apache <?phpinfo();?> responds OK with content.
There are also no ZMS or ZMC processes running after inspecting ps -aux
ZMU returns immediately with no information of my video setup and yet TVtime works perfectly on my camera.
Any help appreciated.
The following are my log files:-
cat /tmp/zmdc.log
Server starting at 06/02/05 12:44:33
'zmfilter.pl' started at 06/02/05 12:44:36
'zmfilter.pl' starting at 06/02/05 12:44:36, pid = 25637
'zmaudit.pl -d 900 -y' starting at 06/02/05 12:44:37, pid = 25643
'zmaudit.pl -d 900 -y' started at 06/02/05 12:44:37
'zmwatch.pl' starting at 06/02/05 12:44:37, pid = 25649
'zmwatch.pl' started at 06/02/05 12:44:37
'zmupdate.pl -c' started at 06/02/05 12:44:38
'zmupdate.pl -c' starting at 06/02/05 12:44:38, pid = 25654
[pthomas@82-70-185-30 tmp]$
cat /tmp/zmpkg.log
Command: start
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmfix'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl status'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmfilter.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmwatch.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmupdate.pl -c'
cat /var/log/httpd/error_messages
[root@82-70-185-30 zm-1.21.4]# cat /var/log/httpd/error_log
[Sat Feb 04 22:11:44 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Feb 04 22:11:45 2006] [notice] Digest: generating secret for digest authentication ...
[Sat Feb 04 22:11:45 2006] [notice] Digest: done
[Sat Feb 04 22:11:45 2006] [notice] Apache/2.0.54 (Mandriva Linux/PREFORK-13mdk) configured -- resuming normal operations
[client 127.0.0.1] PHP Notice: Undefined variable: bandwidth in /var/www/html/zm/zm_html.php on line 21
[client 127.0.0.1] PHP Fatal error: Call to undefined function mysql_pconnect() in /var/www/html/zm/zm_db.php on line 21
[Sun Feb 05 00:46:42 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/zmm
[Sun Feb 05 00:46:54 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/zmm
[Sun Feb 05 00:47:08 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/hj
[Sun Feb 05 00:47:18 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/zmm
[Sun Feb 05 00:47:22 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/hj
[Sun Feb 05 00:47:26 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/hj
[Sun Feb 05 00:47:30 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/hj
[Sun Feb 05 20:25:52 2006] [error] [client 200.27.221.5] File does not exist: /var/www/html/awstats
[Sun Feb 05 20:25:53 2006] [error] [client 200.27.221.5] script not found or unable to stat: /var/www/cgi-bin/awstats.pl
[Sun Feb 05 20:25:55 2006] [error] [client 200.27.221.5] script not found or unable to stat: /var/www/cgi-bin/awstats
[client 200.27.221.5] script '/var/www/html/index2.php' not found or unable to stat
[client 200.27.221.5] script '/var/www/html/index.php' not found or unable to stat
[Sun Feb 05 20:25:58 2006] [error] [client 200.27.221.5] File does not exist: /var/www/html/mambo
[Sun Feb 05 20:26:00 2006] [error] [client 200.27.221.5] File does not exist: /var/www/html/cvs
[Sun Feb 05 20:26:01 2006] [error] [client 200.27.221.5] File does not exist: /var/www/ht
cat /var/log/messages
Feb 5 22:38:38 localhost dhclient: DHCPACK from 82.70.185.31
Feb 5 22:38:38 localhost dhclient: bound to 82.70.185.30 -- renewal in 24 seconds.
Feb 5 22:39:02 localhost dhclient: DHCPREQUEST on eth1 to 82.70.185.31 port 67
Feb 5 22:39:02 localhost dhclient: DHCPACK from 82.70.185.31
Feb 5 22:39:02 localhost dhclient: bound to 82.70.185.30 -- renewal in 31 seconds.
Feb 5 22:39:33 localhost dhclient: DHCPREQUEST on eth1 to 82.70.185.31 port 67
Feb 5 22:39:33 localhost dhclient: DHCPACK from 82.70.185.31
Feb 5 22:39:33 localhost dhclient: bound to 82.70.185.30 -- renewal in 31 seconds.
peter
Mandriva 2006 and zm-1.21.4
Re: Mandriva 2006 and zm-1.21.4
Could these have some thing to do with it?carrthomas wrote: [Sun Feb 05 00:47:18 2006] [error] [client 127.0.0.1] File does not exist: /var/www/html/zmm
Looks like they are looking in the wrong place.
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
