Page 1 of 1
Success and a Big Thank You
Posted: Sun Feb 12, 2006 8:18 pm
by Pete M
Just dropped in to say thank you for a great piece of software
Got Zoneminder running on 2 machines, one amd64 with dual opterons, the other x86 using intel P4
Operating system on both machines is Gentoo
The reason I do 2 installs is because the x86 machine is a mail and DNS server so I can't afford to take it off line, so I iron all the kinks out first on my latest toy, yes I know dual opterons are big boys toys, then install on the server once everything works ok
Did'nt use the Gentoo ebuild, heard bad things so I used the ZoneMinder-1.22.0.tar.gz file instead
Took me a while but got everything working fine including run states via cron
Cam is a Axis 206 only problem I have is resolution, can't get 640x480 working but that's for another day unless one of you guys can point me in the right direction
Time now to add some more cams
Once again Thanks for all your hard work and also for this forum, could'nt have done it without you
Pete
Posted: Sun Feb 12, 2006 8:28 pm
by cordel
Glad, to hear it and Thank you, for the Thank you :wink:
Cheers,
Corey
Re: Success and a Big Thank You
Posted: Mon Feb 13, 2006 8:58 am
by lazyleopard
Pete M wrote:Did'nt use the Gentoo ebuild, heard bad things so I used the ZoneMinder-1.22.0.tar.gz file instead
Yeah, the latest main-line ebuild is giving me conflict problems with my custom one too. Ebuild/emerge is a handy tool until things start conflicting... :/
Posted: Mon Feb 20, 2006 12:03 am
by jameswilson
I would think this is a shared mem issue but you will need to look at the logs first, it could also be your url or cam setup, but i use 206's in high res fine. I even have a few 206m's running at 1280x1024 but you might ned your dual amd64's there lol
Posted: Mon Feb 20, 2006 5:16 pm
by Ruler
I had problems getting cameras to work in 640x480 initially as well. Do a search for shmall or shmmax and you should find the answer, assuming that it's due to the same problem.
Posted: Mon Feb 20, 2006 9:53 pm
by Pete M
Ruler, jameswilson
# echo 134217728 >/proc/sys/kernel/shmall
# echo 134217728 >/proc/sys/kernel/shmmax
Did the trick, will edit /etc/sysctl.conf to make the changes permanent
Only have 8GB ram for the Opteron's hope they can spare it lol
Many thanks for pointing me in the right direction
Pete
