Well guys after my initial success I now have a problem, it's pretty much outlined here
http://www.zoneminder.com/forums/viewto ... +run+state
Created 2 new run states, Day and Night, pretty obvious, saved these and set up cron jobs to control them, Zoneminder changes state as it should at the predetermined times
Problem is the monitors are always disabled at start up and even if I enable them manually Modect does'nt work
If I create a new monitor this works fine until Zoneminder restarts then this is disabled and non functioning as Modect
Please be aware that I am no Mysql guru, the replies in the above post went over my head a little
Hope you can help
Pete
Run States Problem
Sorry to answer my own question but after reading the replies a few times in the link I posted it all started to make sense
So I installed Phpmyadmin edited the states table
From
Name Definition
Day 1:Monitor:
Night 1:Modect:
To
Name Definition
Day 1:Monitor:1
Night 1:Modect:1
And all is now well
Till the next time
Pete
From
Name Definition
Day 1:Monitor:
Night 1:Modect:
To
Name Definition
Day 1:Monitor:1
Night 1:Modect:1
And all is now well
Till the next time
Pete
