create some install faq
fernando
Post by fernando »
iam starting all over.
i install RD base. and iam installing all the need rpms..
and i get stuck in
checking whether round is declared... no
checking for jpeg_start_compress in -ljpeg... no
configure: error: zm requires libjpeg.a
in install it and i have it.. but ...... same error..
iam triing to make a kickstart instalation for ZM.
zoneminder
Site Admin
Re: create some install faq
Post by zoneminder »
Hi Fernando,
I have a FAQ section on the site ready to go live so if you want to post something I'll copy it over. Other than that there is the troubleshooting section of the readme which is pretty much the same.
I think several people have posted that they get the error you are seeing if g++ is not installed, do you have it?
Phil,
fernando
Post by fernando »
ok ........ i cant believe this.. :)...
yes need g++
i install all over again and include g++ and works..
libjpeg-devel
gcc-c++
i love kickstart... i found it yesterday and works like charm from a ftp.. no more cd change...!!
