Could not open config file.
sitxu
Post by sitxu »
[root@mirror zm]# sh bin/zminit
Enter MySQL Administrator username (Default: root and password is blank):
ERROR 1044 (42000) at line 2: Access denied for user ''@'localhost' to database 'zmdb'
ERROR 1062 (23000) at line 376: Duplicate entry 'admin' for key 3
Loading config from '/usr/lib/zm/init/zmconfig.txt'
Loading config from '/etc/zm.conf'
Loading config from DB
Saving config to DB
cordel
Post by cordel »
Can you give more detail as I see an error that I should not see and have no idea why. did you put in the user as root and leave the password blank.
If you can't take time to give more detail, kinkda rude don't you think?
