FC3 rpm upgrade from 1.21.4 -> 1.22.0-1.7 can't start
Posted: Thu Feb 16, 2006 3:44 am
I just downloaded and upgraded my 1.21.4 rpm install to the 1.22.0-1.7 lastest. rpm upgrade went OK, however I have to manually upgrade the database, as trying to start it using /etc/init.d/zm start kept giving me 'manually run the upgrade script'
I ran zmfix.pl, zmupgrade.pl -f and zmupdate.pl --version=1.21.4. everything ran OK. However, zm doesn't start up. When I try to start up I get the following:
Starting ZoneMinder: Can't connect: No such file or directory at /usr/lib/perl5/site_perl/5.8.5/ZoneMinder/Debug.pm line 321
ZoneMinder::Debug::Fatal('Can\'t connect: No such file or directory') called at /usr/lib/zm/bin/zmdc.pl line 141
Looking in /var/log/messages I see:
Feb 15 20:33:17 cx1 zmdc[1220]: INF [Server starting at 06/02/15 20:33:17]
Feb 15 20:33:20 cx1 zmdc[1220]: FAT [Can't bind: Permission denied]
Feb 15 20:33:20 cx1 Can't bind: Permission denied at /usr/lib/perl5/site_perl/5.8.5/ZoneMinder/Debug.pm line 321 ZoneMinder::Debug::Fatal('Can\'t bind: Permission denied') called at /usr/lib/zm/bin/zmdc.pl line 166
Feb 15 20:33:27 cx1 zmdc[1217]: FAT [Can't connect: No such file or directory]
Feb 15 20:33:27 cx1 su(pam_unix)[1216]: session closed for user apache
Feb 15 20:33:27 cx1 zmpkg[1197]: ERR [Unable to run 'su apache -c '/usr/lib/zm/bin/zmdc.pl startup'', output is 'Starting server']
Any ideas?
Any ideas?
