Hi.
My problem is that the card only works with more than 1 Input.
If i have only 1 camera connected the screen is white. It looks like the brightnes is to high.
if i connect a 2. camera the picture gets "darker" and i can see a picture of both cameras.
PyroMUC
GrandTec XGUARD 4 port Problem
i havnt used your card but i have a card that has to have inputs connected if a monitor is working on that input, ie if monitor is set to none then brightness normal, if set to mocord etc and nothing connected i get a flashing to bright image on the other inputs,
might help?
might help?
James Wilson
