What are the minimum system requirements for the LiveCD? As I've discussed in this thread thread, I've been trying to get my video card working on a relatively low specs machine. I'm starting to think the problem may be my distro/kernel build, so I thought I'd try the LiveCD. The problem though, is that I've never met a LiveCD that performs as well as an install, and I can't install another distro on the machine that has the card in it.
Will the live CD function with 128 mb of ram and 750 mhz processor?
Minimum requirements?
it will definetly function on a 750Mhz proc as i use a duron 750 for my home install, but your ram is low. I think that one of the livecd's will boot with 128 meg but its tight and if your using integrated graphics forget it. can you up it to 256
James Wilson
