Page 1 of 1
Minimum requirements?
Posted: Thu Feb 23, 2006 11:40 pm
by AusIV
What are the minimum system requirements for the LiveCD? As I've discussed in this thread thread, I've been trying to get my video card working on a relatively low specs machine. I'm starting to think the problem may be my distro/kernel build, so I thought I'd try the LiveCD. The problem though, is that I've never met a LiveCD that performs as well as an install, and I can't install another distro on the machine that has the card in it.
Will the live CD function with 128 mb of ram and 750 mhz processor?
Posted: Mon Mar 13, 2006 10:38 pm
by jameswilson
it will definetly function on a 750Mhz proc as i use a duron 750 for my home install, but your ram is low. I think that one of the livecd's will boot with 128 meg but its tight and if your using integrated graphics forget it. can you up it to 256
