Not getting an image only image icon after LiveCD install...
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
bucwheat
Post by bucwheat »
Hi all,
I installed Ross' LiveCD and after adding these monitors:
http://ptz.icintracom.com/temp/image.jpg
http://81.206.8.91:82/temp/Moons.jpg
http://82.133.21.77/image.jpg
http://camerademo.dyndns.org:84/Jpeg/CamImg.jpg
All i get is an image icon but no picture. I can access the cams by putting the url into Internet Explorer.
I also tried CTU CD and I get "Failed to connect to server (denied?)" instead of the picture icon.
Please help....
bucwheat
Post by bucwheat »
I changed the resolution in monitor settings and I get a picture now.
bucwheat
Post by bucwheat »
Okay. The others do not work :( I can access them by issuing username / password in dialog box that pops up when i enter the url in IE. How do i pass this info to zm during monitor setup?
Check this site out for example.
http://ptz.icintracom.com/jpg/image.jpg
l/p is guest/guest
zoneminder
Site Admin
Post by zoneminder »
bucwheat wrote:Okay. The others do not work :( I can access them by issuing username / password in dialog box that pops up when i enter the url in IE. How do i pass this info to zm during monitor setup?
l/p is guest/guest
You would have to specify the url as http://guest:guest@ptz.icintracom.com/jpg/image.jpg and it should work.
Phil
