Broken jpg links in Events window: Permissions problem
goodman
Post by goodman »
I am using ZM 1.19.4 on Redhat 9, and recently added a larger hard disk to store my ZM events.
My fstab has been modified with the following:
/dev/hdd1 /var/www/html/zm/events ext3 defaults 1 2
Zoneminder runs ok (I can view video in Montage), it records events, but when i try to view the events throught the ZM events window, I get broken jpeg links, althought the files themselves are present.
Are my permissions for "/var/www/html/zm/events" set incorrectly? Both owner and group are currently set to : apache.
I am still using version 1.19.4, due to previous difficulty with the upgrade process. Until I tried to add the second disk, it was working beautifully! Any help to avoid further downtime much appreciated.
zoneminder
Site Admin
Post by zoneminder »
This may be permissions related, check your httpd error log as it should give you a bit more information.
Phil
