Help needed with GV600 capture card
Posted: Sun Mar 05, 2006 4:24 am
Hi All,
I'm after some help please in getting my Geovision capture card to work in Zoneminder.
I currently have a CTU FC3 system running with a PV149 4 port capture card & a Dynalink capture card. ZoneMinder 1.21.4 seems to be running very well with these two capture cards.
What I would like to be able to do is to get my 4 port GV600 capture card to work & take out the Dynalink card to give me a 8 port system.
The GV600 is detected when the system is booted but shows the card as unknown, I have tried it with card=77 but still no pictures. I get a blue screen from channels 0-3 & a black screen for any other channels. The GV600 has a single BT878 chip.
I also see that since I put the GV600 card in I'm now getting a “buffer size error” on two of the BT878 chips on the PV149 card? Although they seem to be working alright.
Thanks Sika
dmesg
Linux video capture interface: v1.00
bttv: driver version 0.9.15 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ
10
bttv0: Bt878 (rev 2) at 0000:00:0a.0, irq: 10, latency: 64, mmio: 0xcdbfe000
bttv0: detected: (Askey Magic/others) TView99 CPH05x [card=24], PCI subsystem ID
is 144f:3002
bttv0: using: Askey CPH05X/06X (bt878) [many vendors] [card=24,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00feffff [init]
bttv0: radio detected by subsystem id (CPH05x)
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
tvaudio: TV audio decoder + audio/video mux driver
tvaudio: known chips: tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea632
0,tea6420,tda8425,pic16c54 (PV951),ta8874z
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: registered device radio0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv0: add subdevice "remote0"
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ
10
bttv1: Bt878 (rev 17) at 0000:00:0b.0, irq: 10, latency: 64, mmio: 0xcdbfc000
bttv1: subsystem: 600a:584c (UNKNOWN)
please mail id, board name and the correct card= insmod option to kraxel@bytesex
.org
bttv1: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=00fff0ff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt 0000:03:08.0[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ
10
bttv2: Bt878 (rev 17) at 0000:03:08.0, irq: 10, latency: 64, mmio: 0xcdafe000
bttv2: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv2: using: ProVideo PV150 [card=98,insmod option]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt 0000:03:09.0[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ
10
bttv3: Bt878 (rev 17) at 0000:03:09.0, irq: 10, latency: 64, mmio: 0xcdafc000
bttv3: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv3: using: ProVideo PV150 [card=98,insmod option]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (4).
ACPI: PCI Interrupt 0000:03:0a.0[A] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ
11
bttv4: Bt878 (rev 17) at 0000:03:0a.0, irq: 11, latency: 64, mmio: 0xcdafa000
bttv4: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv4: using: ProVideo PV150 [card=98,insmod option]
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv4: using tuner=-1
bttv4: i2c: checking for TDA9875 @ 0xb0... not found
bttv4: i2c: checking for TDA7432 @ 0x8a... not found
bttv4: i2c: checking for TDA9887 @ 0x86... not found
bttv4: registered device video4
bttv4: registered device vbi4
bttv4: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (5).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
ACPI: PCI Interrupt 0000:03:0b.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ
11
bttv5: Bt878 (rev 17) at 0000:03:0b.0, irq: 11, latency: 64, mmio: 0xcdaf8000
bttv5: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv5: using: ProVideo PV150 [card=98,insmod option]
bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv5: using tuner=-1
bttv5: i2c: checking for TDA9875 @ 0xb0... not found
bttv5: i2c: checking for TDA7432 @ 0x8a... not found
bttv5: i2c: checking for TDA9887 @ 0x86... not found
bttv5: registered device video5
bttv5: registered device vbi5
bttv5: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:00:0a.1[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ
10
bt878(0): Bt878 (rev 2) at 00:0a.1, irq: 10, latency: 64, memory: 0xcdbff000
bt878: Bt878 AUDIO function found (1).
ACPI: PCI Interrupt 0000:00:0b.1[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ
10
bt878(1): Bt878 (rev 17) at 00:0b.1, irq: 10, latency: 64, memory: 0xcdbfd000
bt878: Bt878 AUDIO function found (2).
ACPI: PCI Interrupt 0000:03:08.1[A] -> Link [LNKB] -> GSI 10 (level, low) -> IRQ
10
bt878(2): Bt878 (rev 17) at 03:08.1, irq: 10, latency: 64, memory: 0xcdaff000
bt878: Bt878 AUDIO function found (3).
ACPI: PCI Interrupt 0000:03:09.1[A] -> Link [LNKC] -> GSI 10 (level, low) -> IRQ
10
bt878(3): Bt878 (rev 17) at 03:09.1, irq: 10, latency: 64, memory: 0xcdafd000
bt878: Bt878 AUDIO function found (4).
ACPI: PCI Interrupt 0000:03:0a.1[A] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ
11
bt878(4): Bt878 (rev 17) at 03:0a.1, irq: 11, latency: 64, memory: 0xcdafb000
bt878: buffer size error!
bt878: Bt878 AUDIO function found (5).
ACPI: PCI Interrupt 0000:03:0b.1[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ
11
bt878(5): Bt878 (rev 17) at 03:0b.1, irq: 11, latency: 64, memory: 0xcdaf9000
[root@zoneminder bin]# ./zmu -d /dev/video1 -q -v
Video Capabilities
Name: BT878 video (GrandTec Multi Cap
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 352
Height: 288
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Thanks Sika
dmesg
10
is 144f:3002
10
.org
10
10
11
11
10
10
10
10
11
11
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 352
Height: 288
Picture Attributes
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
