So im assuming i have a permission problem. But i dont know how or where to change this. Any ideas?Mar 8 11:16:22 localhost zmu[3614]: ERR [Can't open Cam_1-Zones.jpg: Permission denied]
lost image in zones
lost image in zones
I have upgraded a box from 1.21.3 to 1.22.0 and had a power failure during the rpm upgrade process. As such half the db's were altered and half werent. Anyway i finally got it up and run and all seems great apart from i cant see an image in the zone setup. In the log i have
James Wilson
- zoneminder
- Site Admin
- Contact:
cheers Phil.
Whats the easist way to change this can i use my friend webmin
James Wilson
- zoneminder
- Site Admin
- Contact:
You probably can use webmin but I would suggest using ssh and doing subtituing the appropriate web user and path etc. This is normally done during install so I don't know if that means that other things were not completed. I would check the other directories under your zm dir and apply the same operation.
chown -R apache:apache /var/www/html/zm/images
Phil
i have checked an apache owns everything in the zm folder
James Wilson
- zoneminder
- Site Admin
- Contact:
hold fire i just realised im checkin the wrong box lol hang on
Im such a d1ckhead most of the time!!!!
James Wilson
right once i checkeed the right box it was indeed the images folder was owned by root!
Thanks all sorted
Thanks all sorted
James Wilson
