Card working but no image
Posted: Thu Mar 09, 2006 10:45 am
I picked up a K-world 4 port card and a CCD color/low lux camera. I've gotten this combo to work before using Debian Sarge and the same hardware. I'm trying to do the same now on another machine. I've seen reports in these forums of this card working. I'VE gotten this card to work and from the blue screen in xawtv and ZM, I think the card is working.
The camera is powered by a special power box with screw-in power connectors at exactly the power the cams need. 12VDC 150mA as it is stamped on the camera. I started with a self-crimped BNC cable then switched to a machine made cable from RadioShack.
10 hours later....I have a blue screen when I set the camera in ZM. I'm using RGB24 palette, /dev/video0, channel 0, format 1.
Only strangeness I've noticed is that zmu from the cmd line keeps showing the format switching from PAL to NTSC. i change ZM/xawtv settings accordingly (even tho I think it should be NTSC since i'm in the USA) but still only blue screen
Debian Sarge
Linux 2.6.15.6
K-world 4-input 1-chip card
Intel motherbord chipset
/etc/modprobe.d/bttv:
options bttv card=77 tuner=4
Things I have tried:
- other capture palettes (gray gives black screen. all others besides RGB24 give red screen)
- Tried Sarge's kernel 2.6.8 first. blue screen
- xawtv shows the 4 inputs, but only blue screen. with other drivers xawtv doesn't show all inputs
- tried bttv driver from source. I couldn't get it to compile with kernel 2.6.15.6, but the lastest release is older than the version in my kernel: bttv-0.9.15 release. 0.9.16 in latest kernel
Logs:
- /tmp/zmdc.log
- dmesg
- lspci
- v4l-info
- zmu -d /dev/video0 -q -v
If someone with experience would like to help, remote access is already setup
I'm all out of ideas and forum search topics. Hair is in short supply as well.....
Debian Sarge
Linux 2.6.15.6
Logs:
- /tmp/zmdc.log
'zmwatch.pl' started at 06/03/09 05:13:52
'zmwatch.pl' starting at 06/03/09 05:13:52, pid = 4104
'zmaudit.pl -d 900 -y' running at 06/03/09 05:13:51, pid = 4098, valid
'zma -m 2' running at 06/03/09 05:13:51, pid = 4090, valid
'zmc -d /dev/video0' running at 06/03/09 05:13:51, pid = 4086, valid
'zmfilter.pl' running at 06/03/09 05:13:51, pid = 4094, valid
'zmwatch.pl' running at 06/03/09 05:13:52, pid = 4104, valid
Linux video capture interface: v1.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:02:05.0[A] -> GSI 21 (level, low) -> IRQ 209
bttv0: Bt878 (rev 17) at 0000:02:05.0, irq: 209, latency: 32, mmio: 0xf4000000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: risc main @ 1ec42000
bttv0: gpio: en=00000000, out=00000000 in=00ffefe1 [init]
bttv0: BT878A ARESET
bttv0: using tuner=4
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: video mux: input=0 mux=2
bttv0: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:02:05.1[A] -> GSI 21 (level, low) -> IRQ 209
bt878(0): Bt878 (rev 17) at 02:05.1, irq: 209, latency: 32, memory: 0xf4001000
0000:02:05.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
0000:02:05.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
### v4l2 device info [/dev/video0] ###
general info
VIDIOC_QUERYCAP
driver : "bttv"
card : "BT878 video (GrandTec Multi Cap"
bus_info : "PCI:0000:02:05.0"
version : 0.9.16
capabilities : 0x5000015 [VIDEO_CAPTURE,VIDEO_OVERLAY,VBI_CAPTURE,READWRITE,STREAMING]
standards
VIDIOC_ENUMSTD(0)
index : 0
id : 0xff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K]
frameperiod.numerator : 1
frameperiod.denominator : 25
framelines : 625
VIDIOC_ENUMSTD(1)
index : 1
frameperiod.numerator : 1001
frameperiod.denominator : 30000
framelines : 525
VIDIOC_ENUMSTD(2)
index : 2
id : 0x7f0000 [SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L]
framelines : 625
VIDIOC_ENUMSTD(3)
index : 3
framelines : 625
VIDIOC_ENUMSTD(4)
index : 4
framelines : 525
VIDIOC_ENUMSTD(5)
index : 5
framelines : 625
VIDIOC_ENUMSTD(6)
index : 6
id : 0x2000 [NTSC_M_JP]
framelines : 525
VIDIOC_ENUMSTD(7)
index : 7
framelines : 625
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : CAMERA
audioset : 0
tuner : 0
std : 0x7f3fff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K,PAL_M,PAL_N,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L]
status : 0x102 [NO_SIGNAL,NO_H_LOCK]
VIDIOC_ENUMINPUT(1)
index : 1
type : CAMERA
audioset : 0
tuner : 0
status : 0x0 []
VIDIOC_ENUMINPUT(2)
index : 2
type : CAMERA
audioset : 0
tuner : 0
status : 0x0 []
VIDIOC_ENUMINPUT(3)
index : 3
type : CAMERA
audioset : 0
tuner : 0
status : 0x0 []
video capture
VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
index : 0
type : VIDEO_CAPTURE
flags : 0
description : "8 bpp, gray"
pixelformat : 0x59455247 [GREY]
VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
index : 1
flags : 0
description : "8 bpp, dithered color"
pixelformat : 0x34324948 [HI24]
VIDIOC_ENUM_FMT(2,VIDEO_CAPTURE)
index : 2
flags : 0
description : "15 bpp RGB, le"
pixelformat : 0x4f424752 [RGBO]
VIDIOC_ENUM_FMT(3,VIDEO_CAPTURE)
index : 3
flags : 0
description : "15 bpp RGB, be"
pixelformat : 0x51424752 [RGBQ]
VIDIOC_ENUM_FMT(4,VIDEO_CAPTURE)
index : 4
flags : 0
description : "16 bpp RGB, le"
pixelformat : 0x50424752 [RGBP]
VIDIOC_ENUM_FMT(5,VIDEO_CAPTURE)
index : 5
flags : 0
description : "16 bpp RGB, be"
pixelformat : 0x52424752 [RGBR]
VIDIOC_ENUM_FMT(6,VIDEO_CAPTURE)
index : 6
flags : 0
description : "24 bpp RGB, le"
pixelformat : 0x33524742 [BGR3]
VIDIOC_ENUM_FMT(7,VIDEO_CAPTURE)
index : 7
flags : 0
description : "32 bpp RGB, le"
pixelformat : 0x34524742 [BGR4]
VIDIOC_ENUM_FMT(8,VIDEO_CAPTURE)
index : 8
flags : 0
description : "32 bpp RGB, be"
pixelformat : 0x34424752 [RGB4]
VIDIOC_ENUM_FMT(9,VIDEO_CAPTURE)
index : 9
flags : 0
description : "4:2:2, packed, YUYV"
pixelformat : 0x56595559 [YUYV]
VIDIOC_ENUM_FMT(10,VIDEO_CAPTURE)
index : 10
flags : 0
VIDIOC_ENUM_FMT(11,VIDEO_CAPTURE)
index : 11
flags : 0
description : "4:2:2, packed, UYVY"
pixelformat : 0x59565955 [UYVY]
VIDIOC_ENUM_FMT(12,VIDEO_CAPTURE)
index : 12
flags : 0
description : "4:2:2, planar, Y-Cb-Cr"
pixelformat : 0x50323234 [422P]
VIDIOC_ENUM_FMT(13,VIDEO_CAPTURE)
index : 13
flags : 0
description : "4:2:0, planar, Y-Cb-Cr"
pixelformat : 0x32315559 [YU12]
VIDIOC_ENUM_FMT(14,VIDEO_CAPTURE)
index : 14
flags : 0
description : "4:2:0, planar, Y-Cr-Cb"
pixelformat : 0x32315659 [YV12]
VIDIOC_ENUM_FMT(15,VIDEO_CAPTURE)
index : 15
flags : 0
description : "4:1:1, planar, Y-Cb-Cr"
pixelformat : 0x50313134 [411P]
VIDIOC_ENUM_FMT(16,VIDEO_CAPTURE)
index : 16
flags : 0
description : "4:1:0, planar, Y-Cb-Cr"
pixelformat : 0x39565559 [YUV9]
VIDIOC_ENUM_FMT(17,VIDEO_CAPTURE)
index : 17
flags : 0
description : "4:1:0, planar, Y-Cr-Cb"
pixelformat : 0x39555659 [YVU9]
VIDIOC_G_FMT(VIDEO_CAPTURE)
fmt.pix.width : 320
fmt.pix.height : 240
fmt.pix.pixelformat : 0x33524742 [BGR3]
fmt.pix.field : INTERLACED
fmt.pix.bytesperline : 960
fmt.pix.sizeimage : 230400
fmt.pix.colorspace : unknown
fmt.pix.priv : 0
video overlay
VIDIOC_ENUM_FMT(0,VIDEO_OVERLAY)
index : 0
type : VIDEO_OVERLAY
flags : 0
VIDIOC_ENUM_FMT(1,VIDEO_OVERLAY)
index : 1
flags : 0
VIDIOC_ENUM_FMT(2,VIDEO_OVERLAY)
index : 2
flags : 0
VIDIOC_ENUM_FMT(3,VIDEO_OVERLAY)
index : 3
flags : 0
VIDIOC_ENUM_FMT(4,VIDEO_OVERLAY)
index : 4
flags : 0
VIDIOC_ENUM_FMT(5,VIDEO_OVERLAY)
index : 5
flags : 0
VIDIOC_ENUM_FMT(6,VIDEO_OVERLAY)
index : 6
flags : 0
VIDIOC_ENUM_FMT(7,VIDEO_OVERLAY)
index : 7
flags : 0
VIDIOC_ENUM_FMT(8,VIDEO_OVERLAY)
index : 8
flags : 0
VIDIOC_ENUM_FMT(9,VIDEO_OVERLAY)
index : 9
flags : 0
VIDIOC_ENUM_FMT(10,VIDEO_OVERLAY)
index : 10
flags : 0
VIDIOC_ENUM_FMT(11,VIDEO_OVERLAY)
index : 11
flags : 0
VIDIOC_G_FMT(VIDEO_OVERLAY)
fmt.win.w.left : 0
fmt.win.w.top : 0
fmt.win.w.width : 320
fmt.win.w.height : 240
fmt.win.field : ANY
fmt.win.chromakey : 0
fmt.win.clips : (nil)
fmt.win.clipcount : 0
fmt.win.bitmap : (nil)
VIDIOC_G_FBUF
capability : 0x4 [LIST_CLIPPING]
flags : 0x0 []
base : (nil)
fmt.width : 0
fmt.height : 0
fmt.pixelformat : 0x00000000 [....]
fmt.field : ANY
fmt.bytesperline : 0
fmt.sizeimage : 0
fmt.colorspace : unknown
fmt.priv : 0
vbi capture
VIDIOC_ENUM_FMT(0,VBI_CAPTURE)
index : 0
type : VBI_CAPTURE
flags : 0
description : "vbi data"
VIDIOC_G_FMT(VBI_CAPTURE)
type : VBI_CAPTURE
fmt.vbi.sampling_rate : 35468950
fmt.vbi.offset : 244
fmt.vbi.samples_per_line: 2048
fmt.vbi.sample_format : 0x59455247 [GREY]
fmt.vbi.start[0] : 7
fmt.vbi.start[1] : 319
fmt.vbi.count[0] : 16
fmt.vbi.count[1] : 16
fmt.vbi.flags : 0
controls
VIDIOC_QUERYCTRL(BASE+0)
type : INTEGER
minimum : 0
maximum : 65535
step : 256
default_value : 32768
flags : 0
VIDIOC_QUERYCTRL(BASE+1)
type : INTEGER
minimum : 0
maximum : 65535
step : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+2)
type : INTEGER
minimum : 0
maximum : 65535
step : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+3)
type : INTEGER
minimum : 0
maximum : 65535
step : 256
flags : 0
VIDIOC_QUERYCTRL(BASE+9)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+0)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+1)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+2)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+3)
type : BOOLEAN
name : "luma decimation filter"
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+4)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+5)
type : BOOLEAN
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+6)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 207
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+7)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 127
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+8)
type : INTEGER
minimum : 0
maximum : 100
step : 1
default_value : 50
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+9)
type : BOOLEAN
name : "full luma range"
minimum : 0
maximum : 1
step : 0
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(PRIVATE_BASE+10)
type : INTEGER
minimum : 0
maximum : 3
step : 1
default_value : 0
flags : 0
### video4linux device info [/dev/video0] ###
general info
VIDIOCGCAP
name : "BT878 video (GrandTec Multi Cap"
type : 0xab [CAPTURE,TUNER,OVERLAY,CLIPPING,SCALES]
channels : 4
audios : 0
maxwidth : 924
maxheight : 576
minwidth : 48
minheight : 32
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x2 [AUDIO]
type : CAMERA
norm : 0
VIDIOCGCHAN(1)
channel : 1
tuners : 0
flags : 0x2 [AUDIO]
type : CAMERA
norm : 0
VIDIOCGCHAN(2)
channel : 2
tuners : 0
flags : 0x2 [AUDIO]
type : CAMERA
norm : 0
VIDIOCGCHAN(3)
channel : 3
tuners : 0
flags : 0x2 [AUDIO]
type : CAMERA
norm : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
VIDIOCGAUDIO
audio : 0
volume : 0
bass : 0
treble : 0
VIDIOCGPICT
brightness : 32768
hue : 32768
colour : 32768
contrast : 32768
whiteness : 0
depth : 24
palette : RGB24
buffer
VIDIOCGFBUF
base : (nil)
height : 0
width : 0
depth : 1
bytesperline : 0
window
VIDIOCGWIN
x : 0
y : 0
width : 320
height : 240
chromakey : 0
flags : 0
Video Capabilities
Name: BT878 video (GrandTec Multi Cap
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
