Signal loss on network camera
Marinator
Post by Marinator »
I have just added a wireless camera, but I am getting thousands of signal loss events on it when I set it to Modetect. I have another camera that is working fine. I thought signal loss was only on local camera's. I have deleted the camera and re-created it, but there is no change. I have tried modifying the ZM_SIGNAL_CHECK_POINTS value to 1 and 1000, but it makes no real difference. I get about one event per second. Ist here a way to suppress this function in the config files? I only have remote cameras adn have no need for it.
Thanks in advance
Marinator
Post by Marinator »
Does anyone have any ideas?
I have used this same camera for years with Zoneminder with no problems and this problem just came up after a crash and reinstall of 1.22.0. This seems to be a type of bug in that Signal loss events should not be recorded for network cameras. I have deleted and recreated the monitor several times with no change. The video is in Monitor is fine, but in any of the other modes(except None) thousands of Signal events are generated every hour.
wmoore
Post by wmoore »
I am experiencing the same issue, although I also have problems with the images being garbled frequently. I believe mine might me a memory issue.
Have you reviewed /var/log/messages ?
I found warning about potential buffer overruns that o believe are symptomatic of a problem ZM is interpreting as a LOS.
If my memupgrade corrects it, Ill post.
-WAM
Marinator
Post by Marinator »
This is my /var/log/messages
server:~ # tail -n 50 /var/log/messages
Mar 11 22:01:16 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:21 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:27 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:35 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:39 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:43 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:44 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:48 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:54 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:01:57 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:04 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:09 server zmc_m7[5994]: INF [Tommy: 12000 - Capturing at 2.05 fps]
Mar 11 22:02:11 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:16 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:22 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:27 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:35 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:41 server zmc_m6[7951]: ERR [Select timed out]
Mar 11 22:02:41 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:46 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:47 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:48 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:53 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:02:54 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:02 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:05 server zma_m7[5247]: INF [Tommy: 35000 - Processing at 1.98 fps]
Mar 11 22:03:08 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:12 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:16 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:17 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:19 server zmc_m6[7951]: INF [Shed: 1000 - Capturing at 6.71 fps]
Mar 11 22:03:20 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:27 server zmdc[5220]: INF ['zma -m 7' stopping at 06/03/11 22:03:27]
Mar 11 22:03:28 server zma_m7[5247]: INF [Got signal (Terminated), exiting]
Mar 11 22:03:28 server zmdc[5220]: INF ['zma -m 7' died]
Mar 11 22:03:28 server zmdc[8127]: INF ['zma -m 7' started at 06/03/11 22:03:28]
Mar 11 22:03:28 server zmdc[5220]: INF ['zma -m 7' starting at 06/03/11 22:03:28, pid = 8127]
Mar 11 22:03:28 server zma_m7[8127]: INF [Debug Level = 0, Debug Log = <none>]
Mar 11 22:03:28 server zma_m7[8127]: INF [In mode 3/1, warming up]
Mar 11 22:03:28 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:33 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:37 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
Mar 11 22:03:41 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
This is /tmp/zmdc.logserver:~ # tail -n 50 /tmp/zmdc.log
Not a JPEG file: starts with 0xc7 0x06
03/11/06 18:37:20.667887 zmdc[5220].ERR ['zmc -m 6' crashed, exit status 1]
03/11/06 18:37:30.363642 zmdc[5689].INF ['zmc -m 6' started at 06/03/11 18:37:30]
03/11/06 18:37:30.367169 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 18:37:30, pid = 5689]
Not a JPEG file: starts with 0xfa 0x73
03/11/06 18:37:48.490738 zmdc[5220].ERR ['zmc -m 6' crashed, exit status 1]
03/11/06 18:38:00.895902 zmdc[5693].INF ['zmc -m 6' started at 06/03/11 18:38:00]
03/11/06 18:38:00.901059 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 18:38:00, pid = 5693]
Not a JPEG file: starts with 0xbc 0x74
03/11/06 19:18:11.911797 zmdc[5220].ERR ['zmc -m 6' crashed, exit status 1]
03/11/06 19:18:24.129834 zmdc[5828].INF ['zmc -m 6' started at 06/03/11 19:18:24]
03/11/06 19:18:24.132516 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 19:18:24, pid = 5828]
03/11/06 20:04:17.738022 zmdc[5220].INF ['zmc -m 7' stopping at 06/03/11 20:04:17]
03/11/06 20:04:17.742485 zmdc[5220].ERR ['zmc -m 7' crashed, exit status 255]
03/11/06 20:04:17.840381 zmdc[5220].INF [Starting pending process, zmc -m 7]
03/11/06 20:04:17.842589 zmdc[5971].INF ['zmc -m 7' started at 06/03/11 20:04:17]
03/11/06 20:04:17.844643 zmdc[5220].INF ['zmc -m 7' starting at 06/03/11 20:04:17, pid = 5971]
03/11/06 20:04:28.050734 zmdc[5220].INF ['zmc -m 7' stopping at 06/03/11 20:04:28]
03/11/06 20:04:28.055099 zmdc[5220].ERR ['zmc -m 7' crashed, exit status 255]
03/11/06 20:04:33.073232 zmdc[5220].INF [Starting pending process, zmc -m 7]
03/11/06 20:04:33.075419 zmdc[5984].INF ['zmc -m 7' started at 06/03/11 20:04:33]
03/11/06 20:04:33.085528 zmdc[5220].INF ['zmc -m 7' starting at 06/03/11 20:04:33, pid = 5984]
03/11/06 20:05:08.450784 zmdc[5220].INF ['zmc -m 7' stopping at 06/03/11 20:05:08]
03/11/06 20:05:08.454944 zmdc[5220].ERR ['zmc -m 7' crashed, exit status 255]
03/11/06 20:05:18.020139 zmdc[5220].INF [Starting pending process, zmc -m 7]
03/11/06 20:05:18.022330 zmdc[5988].INF ['zmc -m 7' started at 06/03/11 20:05:18]
03/11/06 20:05:18.024405 zmdc[5220].INF ['zmc -m 7' starting at 06/03/11 20:05:18, pid = 5988]
03/11/06 20:06:18.833316 zmdc[5220].INF ['zmc -m 7' stopping at 06/03/11 20:06:18]
03/11/06 20:06:18.837516 zmdc[5220].ERR ['zmc -m 7' crashed, exit status 255]
03/11/06 20:06:29.151921 zmdc[5994].INF ['zmc -m 7' started at 06/03/11 20:06:29]
03/11/06 20:06:29.156810 zmdc[5220].INF ['zmc -m 7' starting at 06/03/11 20:06:29, pid = 5994]
03/11/06 21:17:09.204995 zmdc[5220].ERR ['zmc -m 6' crashed, exit status 255]
03/11/06 21:17:09.291760 zmdc[5220].INF [Starting pending process, zmc -m 6]
03/11/06 21:17:09.354630 zmdc[7258].INF ['zmc -m 6' started at 06/03/11 21:17:09]
03/11/06 21:17:09.459760 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 21:17:09, pid = 7258]
03/11/06 21:17:31.382511 zmdc[5220].INF ['zmc -m 6' stopping at 06/03/11 21:17:31]
03/11/06 21:17:37.408566 zmdc[5220].INF ['zmc -m 6' died, signal 8]
03/11/06 21:17:42.081163 zmdc[5220].INF [Starting pending process, zmc -m 6]
03/11/06 21:17:42.083449 zmdc[7334].INF ['zmc -m 6' started at 06/03/11 21:17:42]
03/11/06 21:17:42.085424 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 21:17:42, pid = 7334]
03/11/06 21:18:16.639292 zmdc[5220].INF ['zmc -m 6' stopping at 06/03/11 21:18:16]
03/11/06 21:18:16.738681 zmdc[5220].INF ['zmc -m 6' died]
03/11/06 21:18:17.057461 zmdc[5220].WAR [Can't find process with command of 'zma -m 6']
03/11/06 22:00:49.852172 zmdc[5220].INF ['zmc -m 6' starting at 06/03/11 22:00:49, pid = 7951]
03/11/06 22:00:49.853591 zmdc[7951].INF ['zmc -m 6' started at 06/03/11 22:00:49]
03/11/06 22:00:50.543686 zmdc[5220].WAR [Can't find process with command of 'zma -m 6']
03/11/06 22:03:27.948830 zmdc[5220].INF ['zma -m 7' stopping at 06/03/11 22:03:27]
03/11/06 22:03:28.162244 zmdc[5220].INF ['zma -m 7' died]
03/11/06 22:03:28.597357 zmdc[8127].INF ['zma -m 7' started at 06/03/11 22:03:28]
03/11/06 22:03:28.599791 zmdc[5220].INF ['zma -m 7' starting at 06/03/11 22:03:28, pid = 8127]
Any other logs I can check. I don't really know what to check next.
Marin
zoneminder
Site Admin
Post by zoneminder »
Marinator wrote:Mar 11 22:01:16 server zmc_m6[7951]: ERR [Invalid response status 404: Not found]
This is basically what it says on the tin, and has th esame meaning as a 404 error on a browser. Basically the path you have entered to fetch your image does not appear to exist. Check your monitor setup to make sure you have used a valid path.
Phil
Marinator
Post by Marinator »
Is there anything else that can cause this error? I can see the video stream fine in the monitor window and of course I can wget an image. I have checked my Apache error logs but they have no useful info. Here is my Apache access log. Are ther other logs I can check other than Messages, zmdc.log and zmwatch.log?
server:/var/log/apache2 # tail -n 50 /var/log/apache2/access_log
192.168.2.106 - - [15/Mar/2006:21:02:25 -0800] "GET /zm/zm.php HTTP/1.1" 200 1949 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
24.202.102.37 - - [15/Mar/2006:21:05:40 -0800] "HEAD / HTTP/1.0" 200 - "-" "PHP version tracker (http://www.nexen.net/phpversion/bot.php)"
192.168.2.106 - - [15/Mar/2006:21:07:26 -0800] "GET /zm/zm.php HTTP/1.1" 200 1949 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:12:26 -0800] "GET /zm/zm.php HTTP/1.1" 200 1949 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:28 -0800] "GET /zm/zm.php?view=state HTTP/1.1" 200 780 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:29 -0800] "POST /zm/zm.php HTTP/1.1" 200 659 "http://www.md71.com/zm/zm.php?view=state" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:30 -0800] "GET /zm/zm.php?view=none&action=state&run_state=start HTTP/1.1" 200 201 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:38 -0800] "GET /zm/zm.php HTTP/1.1" 200 2007 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:39 -0800] "GET /zm/zm_html_styles.css HTTP/1.1" 200 1157 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:39 -0800] "GET /zm/graphics/seq-d.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:16:39 -0800] "GET /zm/graphics/seq-u.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:21:39 -0800] "GET /zm/zm.php HTTP/1.1" 200 2005 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=watch&mid=6 HTTP/1.1" 200 471 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=watchmenu&mode=&mid=6&scale=100&control= HTTP/1.1" 200 666 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=watchfeed&mode=&mid=6&scale=100&control= HTTP/1.1" 200 376 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=watchstatus&mid=6&control= HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=blank HTTP/1.1" 200 123 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:22 -0800] "GET /zm/zm.php?view=watchevents&max_events=10&mid=6 HTTP/1.1" 200 1190 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:27 -0800] "GET /zm/zm.php?view=watchstatus&mid=6&last_status=0 HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watc ... 6&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:23 -0800] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=6&scale=100&maxfps=15&rand=1142486782 HTTP/1.1" 200 - "http://www.md71.com/zm/zm.php?view=watc ... 0&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:31 -0800] "GET /zm/zm.php?view=function&mid=7 HTTP/1.1" 200 609 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:34 -0800] "GET /zm/zm.php?view=none&action=function&mid=7&new_function=Monitor&new_enabled=1 HTTP/1.1" 200 201 "http://www.md71.com/zm/zm.php?view=function&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:35 -0800] "GET /zm/zm.php HTTP/1.1" 200 1996 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:36 -0800] "GET /zm/zm_html_styles.css HTTP/1.1" 200 1157 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:36 -0800] "GET /zm/graphics/seq-u.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:26:36 -0800] "GET /zm/graphics/seq-d.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:48 -0800] "GET /zm/zm.php?view=watch&mid=7 HTTP/1.1" 200 473 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /zm/zm.php?view=watchmenu&mode=&mid=7&scale=100&control= HTTP/1.1" 200 667 "http://www.md71.com/zm/zm.php?view=watch&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /zm/zm.php?view=watchfeed&mode=&mid=7&scale=100&control= HTTP/1.1" 200 376 "http://www.md71.com/zm/zm.php?view=watch&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /zm/zm.php?view=watchstatus&mid=7&control= HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watch&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /zm/zm.php?view=blank HTTP/1.1" 200 123 "http://www.md71.com/zm/zm.php?view=watch&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /zm/zm.php?view=watchevents&max_events=10&mid=7 HTTP/1.1" 200 1827 "http://www.md71.com/zm/zm.php?view=watch&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:53 -0800] "GET /zm/zm.php?view=watchstatus&mid=7&last_status=0 HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watc ... 7&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:30:49 -0800] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=7&scale=100&maxfps=15&rand=1142487049 HTTP/1.1" 200 - "http://www.md71.com/zm/zm.php?view=watc ... 0&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:31:36 -0800] "GET /zm/zm.php HTTP/1.1" 200 1996 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:40 -0800] "GET /zm/zm.php?view=function&mid=7 HTTP/1.1" 200 609 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:42 -0800] "GET /zm/zm.php?view=none&action=function&mid=7&new_function=None&new_enabled=1 HTTP/1.1" 200 201 "http://www.md71.com/zm/zm.php?view=function&mid=7" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:44 -0800] "GET /zm/zm.php HTTP/1.1" 200 1954 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:45 -0800] "GET /zm/zm_html_styles.css HTTP/1.1" 200 1157 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:45 -0800] "GET /zm/graphics/seq-u.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:32:45 -0800] "GET /zm/graphics/seq-d.gif HTTP/1.1" 200 68 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=watch&mid=6 HTTP/1.1" 200 471 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=watchmenu&mode=&mid=6&scale=100&control= HTTP/1.1" 200 666 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=watchevents&max_events=10&mid=6 HTTP/1.1" 200 1190 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=blank HTTP/1.1" 200 123 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=watchfeed&mode=&mid=6&scale=100&control= HTTP/1.1" 200 374 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:34 -0800] "GET /zm/zm.php?view=watchstatus&mid=6&control= HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watch&mid=6" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:35 -0800] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=6&scale=100&maxfps=15&rand=1142487274 HTTP/1.1" 200 - "http://www.md71.com/zm/zm.php?view=watc ... 0&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:34:39 -0800] "GET /zm/zm.php?view=watchstatus&mid=6&last_status=0 HTTP/1.1" 200 360 "http://www.md71.com/zm/zm.php?view=watc ... 6&control=" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
192.168.2.106 - - [15/Mar/2006:21:37:45 -0800] "GET /zm/zm.php HTTP/1.1" 200 1955 "http://www.md71.com/zm/zm.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.1) Gecko/20060111 Firefox/1.5.0.1"
zoneminder
Site Admin
Can you do a
zmu -m 1 -q -v
substituting 1 for your monitor id and then post the results.
Phil
Marinator
Post by Marinator »
Here it is.
server:~ # zmu -m 6 -q -v
Monitor 6(Shed)
Type : Remote
Host : 192.168.2.11
Port : 80
Path : /__live.jpg?&&&
Width : 640
Height : 480
Palette : 4
Colours : 3
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 40
Warmup Count : 20
Pre Event Count : 15
Post Event Count : 15
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 8.00
Reference Blend %ge : 7
Track Motion : 0
Function: 2 - Monitor
Zones : 1
Label : All
Type: 1 - Active
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 3
Max Alarm Pixels : 75
Filter Box : 3,3
Min Filter Pixels : 3
Max Filter Pixels : 75
Min Blob Pixels : 2
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
Marinator
Post by Marinator »
OK, I have it working better now. I have to turn the Max FPS down to 2 or less or else I get the 404 error. This triggers a signal loss error. Is there a way to supress the signal loss error checking completely?
zoneminder
Site Admin
There should be no possibility for geting a signal loss error on a network camera, it just doesn't go down that path so that baffles me a bit. Also fps should not affect whether your camera can server up pages, it either can or it can't and I don't see why it might decide that if it's busy that it will return a 404 when a 500 would be more appropriate I would have thought.
Phil
wmoore
Post by wmoore »
Hate to differ,
But I get the signal loss / signal restored events all the time... and I only have network cameras. Only happins in the AXIS camera. Panasonic works fine.
How can I help you get to the bottom of it?
-WAM
zoneminder
Site Admin
That is very odd. I will have to have another look at the code and see if I changed it since 1.22.0 and have just forgotten!
Phil
jameswilson
Post by jameswilson »
that soundslike me lol
James Wilson
Marinator
Post by Marinator »
Any updates on this or thoughts on what else to try? I would like to increaset the frame rate, but I get too many Signal events if I do. Right now I am at about 10 per day which is manageable.
wmoore
Post by wmoore »
Marinator,
What type of camera do you have?
I have Axis. Under version 1.22.1 I was forced to change my host path from mjpg to jpg in order to improve my issues. Dont think our issues were the same exactly, but it may be worth a shot.
-WAM
