I am trying to get a AXIS 2100 network camera working with zoneminder. I have non-networked cameras working fine with zoneminder, so I am going to go out on a bridge and say my installation and configuration is working fine. Don't stone me too bad.
The IP address of the network camera is 10.10.10.1.
I am using the following configuration as a Monitor.
Source Type = Remote
Function = Monitor
Enabled = Check
Max FPS = 0
Reference Blend = 7
Source
Remote Host = Http://10.10.10.1
Port = 80
Path = /cgi-bin/hugesize.jpg?motion=0 (Not sure this is right)
Colours = 8-bit gray
width = 320
height = 240
FYI. There is a password required to view it from it native web site. I don't know how to tell zoneminder to use a username and password or how to remove the password all together from the AXIS 2100.
With the above configuration I just get a red Http://10.10.10.1 under the Source on the main page.
Thanks in Advance and Yes I have it working under SLACKWARE. SLACKWARE Rocks@@@
Axis 2100 v2.02 and Zoneminder with Password
i dont know about the path, but to pass user name etc use
user:password@ip
axis cams are great apart from a post i read on here re a mem leak on a 207
user:password@ip
James Wilson
in the host with the ip!
To be honest while your learnign and playing id disable all the security and add that at the end once you know all is good!
James Wilson
