Hi all,
I followed closely using this thread as my guide and managed to install ZM on SUSE 10: http://www.zoneminder.com/forums/viewto ... light=suse
Everything seems to be working great so far execpt I can't delete any Monitors. I setup one camera, its working great. Played around with a second one. Decided to stick to 1 at the moment for test reasons... Then went to remove it and it won't be removed from the web interface.
I am doing a tail -f on the following log files which produces no errors.
/tmp/
zmaudit.log
zmupdate.log
zmwatch.log
zmpkg.log
zmdc.log
/var/log/messages
No error messages, nada. Maybe I should increase the debug output? If anyone has any ideas please let me know!
Machine specs:
Motherboard: P4C800-E Deluxe
RAM: Kingston 1GB (Two 512mb pieces.)
CPU: 3.4ghz
RAID: 3ware 9500S-4 port
HD: 300GB Maxtor SATA (RAID 1)
Video: Nvidia 6800GT
Thanks for your time!
Zoneminder 1.22.0 / SUSE 10 / Can't delete monitor.
- zoneminder
- Site Admin
- Contact:
Ahh sorry I had been searching already quite a bit for other little quirks here and there I was dealing with. Sorry for the trouble and thanks for the info. I guess searching this subject slipped my mind.zoneminder wrote:There was a bug in 1.22.0 with deleting monitors. If you search the forums you should find a patch otherwise you can delete them from the DB. Version 1.22.1 has been ready for a few weeks now I'm just having trouble finding the time to actually release it but it should be any time now.
Thanks again.
Edit: Found it...: http://www.zoneminder.com/forums/viewto ... te+monitor
