ZM .16 Beta Update
Posted: Wed Nov 05, 2003 4:49 pm
All,
A slightly updated version of the beta can be had from http://www.zoneminder.com/downloads/zm- ... 105.tar.gz if you want to try it.
Changes from the previous beta are :-
- Increased SQL buffer size to cope with large pre-event buffers, plus a couple of other buffers have been enlarged.
- The time offsets in alarmed frames were incorrect and based on the time of storage rather than capture. This gave the impression that there was a delay after the first alarmed frame and messed up some streaming timings. This has been fixed.
- You can now view details of the frames captured such as their time and score etc by clicking on the scores in the events views.
- Fixed zmfilter, zmwatch and zmx10 to allow zero as a valid shared memory id to allow them to keep on working if the segment has been marked for deletion
- Changed image buffer in zmf to be static rather than dynamic. This has made zmf much more stable.
- Fixed the 'Overwrite' checkbox in video generation to actually overwite the video. Modded the page slightly also.
Hopefully these are all useful. There's no DB changes so you should be able to just untar this over your existing distribution. There are additional files though so you may have to rerun configure etc.
Cheers,
Phil,
Cheers,
Phil,
