Ok, I log into the ZM site and click on the monitor name on the left. It spawns the window and tries to load the java then crashed the TCP/IP stack and I can't get any network functions to work... period without rebooting...
Did the exact same function with home machine and instead of crashing the tcp/IP stack it rebooted the PC.....
All the clients are running XP PRO, all have all service packs, all have the Windows client veiwer (that appears to work fine now James... Thanks)
Anyone have any ideas??
Web Viewer/Monitor Crashing TCP/IP Stack and then also Syste
i really dont know on this as i cant see why it shoudl cause a problem I assume you are using sun jave and its upto date, i only say that as i use the sun jvm. Also glad to hear that zm4ms is sorted for you !
James Wilson
Zoneminder Crashing Systems...
Ok, after EXTENSIVE testing I have come to the conslusion something isn't quite right...
We are running 1.22 but this problem happened from the live cd version and then 1.21.?? so it isn't a new problem...
The problem first appear on a the first machine I installed it one and appeared as crashing the IP stack and all networkfunctions become inop upon trying to view video like Montage or even a single screen...
I tried this on another machine and yes, it was doing the same thing... only on the second machine it didn't require a reboot to fix just a ctrl alt dlt and end task and the network came back up, but on the first machine it required a reboot. Both these machines are XP Pro...
So Now I got a different laptop at home, fresh install of 2000 with SP4 then launched into the website and tried to view the montage or a screen and Walla, blue screen of death and reboot....
Now I'm installing the latest java and will post the results soon....
ANYONE have these problems?
