fedora 3 - Access denied for user: 'ZM_DB_USER@localhost'
8ace
Post by 8ace »
just loaded cordel's fedora 3 dsic w/no probs except this message. Any suggestions anyone?
Could not connect to database: Access denied for user: 'ZM_DB_USER@localhost' (Using password: YES)
cordel
Post by cordel »
Looks like the database user was not set properly.
Make sure you have the correct user and password set in /etc/zm.conf
Make sure the database was created.
Then if make sure you have run zminit.
Regards,
Corey
8ace
Post by 8ace »
thanks Corey, I will check /etc/zm.conf this evening. :D
8ace
Post by 8ace »
hi Corey - I added user root (password blank) into zm.conf.
But when I run zminit I get
ERROR (/etc/zm.conf): ZM_DB_PASS should exist and not be empty.
what do I need to do with / what is ZM_DB_PASS?
thx
8ace
Post by 8ace »
ahh ... I read the instructions wrong. I added root as the id and blank as the password in zm.conf!
zm is up. Discounting time lost due to my unbridled enthusiasm, total install time - 30 mins or less!
Thanks!
cordel
Post by cordel »
:lol: I remember being that way a few years back too :D
Cheers,
Corey
8ace
Post by 8ace »
No one likes good news, but...
1. absolutely standard Fedora install from Corey
2. 7 video cameras - FOUR miscellaneous junky BT cards in my 1.something GHz AMD(one 4pt ebay spesh) and a mix of odd tuner and capture cards.
3. Absolutely no special configurations carried out (wouldn;t know how to anyway)
3. My homemade web pages are now sitting in the root, with zm in /zm/ - running dyndns through IPCOP (Cheapsville, USA!)
Astonishing. With the exception of my not being able to read properly, let's make that 1 hours total install time!
thanks Corey and have a great evening....
jameswilson
Post by jameswilson »
good news you bas..... lol
Glad your up and running
James Wilson
cordel
Post by cordel »
Glad you got it all figured out.
Enjoy :D
Corey
