Page 1 of 1
fedora 3 - Access denied for user: 'ZM_DB_USER@localhost'
Posted: Mon Mar 20, 2006 4:25 am
by 8ace
just loaded cordel's fedora 3 dsic w/no probs except this message. Any suggestions anyone?
Could not connect to database: Access denied for user: 'ZM_DB_USER@localhost' (Using password: YES)
Posted: Mon Mar 20, 2006 8:29 am
by cordel
Looks like the database user was not set properly.
Make sure you have the correct user and password set in /etc/zm.conf
Make sure the database was created.
Then if make sure you have run zminit.
Regards,
Corey
Posted: Mon Mar 20, 2006 2:39 pm
by 8ace
thanks Corey, I will check /etc/zm.conf this evening.
Posted: Tue Mar 21, 2006 1:30 am
by 8ace
hi Corey - I added user root (password blank) into zm.conf.
But when I run zminit I get
ERROR (/etc/zm.conf): ZM_DB_PASS should exist and not be empty.
what do I need to do with / what is ZM_DB_PASS?
thx
Posted: Tue Mar 21, 2006 3:16 am
by 8ace
ahh ... I read the instructions wrong. I added root as the id and blank as the password in zm.conf!
zm is up. Discounting time lost due to my unbridled enthusiasm, total install time - 30 mins or less!
Thanks!
Posted: Tue Mar 21, 2006 8:49 pm
by cordel
I remember being that way a few years back too
Cheers,
Corey
Posted: Wed Mar 22, 2006 2:23 am
by 8ace
No one likes good news, but...
1. absolutely standard Fedora install from Corey
2. 7 video cameras - FOUR miscellaneous junky BT cards in my 1.something GHz AMD(one 4pt ebay spesh) and a mix of odd tuner and capture cards.
3. Absolutely no special configurations carried out (wouldn;t know how to anyway)
3. My homemade web pages are now sitting in the root, with zm in /zm/ - running dyndns through IPCOP (Cheapsville, USA!)
Astonishing. With the exception of my not being able to read properly, let's make that 1 hours total install time!
thanks Corey and have a great evening....
Posted: Wed Mar 22, 2006 8:16 am
by jameswilson
good news you bas..... lol
Glad your up and running
Posted: Wed Mar 22, 2006 10:19 am
by cordel
Glad you got it all figured out.
Enjoy
Corey
