I did stop zm first, it didn't give me message about updating db. When I try to start zm it says: You must run zmupdate.pl manualy
So I tried that with -f option, I get:
Update agent starting at 06/03/20 03:26:05
Freshening configuration in database
Loading config from DB
Saving config to DB
Update agent exiting at 06/03/20 03:26:05
Then trying to start zm again I still get the same You must run zmupdate.pl manualy
What can I check to fix this ?
