Page 1 of 1
is there way to tell ZM to use the Java applet of TV-IP100W
Posted: Tue Mar 21, 2006 4:32 pm
by antar
I have ZM installed and working (detection) but no streaming in Firefox 1.5
in both cases : with cambozola and without it.
is there way to tell ZM to use the Java applet that comes with trendnet TV-IP100W and avoid using cambozola
Posted: Tue Mar 21, 2006 4:36 pm
by jameswilson
i would expect if it recording its a permission thing. what do your logs say when you try to view
Posted: Tue Mar 21, 2006 4:39 pm
by antar
Var/log/messages says this:
Mar 20 08:03:20 test zmdc[5047]: INF ['zmc -m 1' started at 06/03/20 08:03:20]
Mar 20 08:03:20 test zmdc[4841]: INF ['zmc -m 1' starting at 06/03/20 08:03:20, pid = 5047]
Mar 20 08:03:20 test zmc_m1[5047]: INF [Debug Level = 0, Debug Log = <none>]
Mar 20 08:03:20 test zmc_m1[5047]: ERR [Attempting to crop outside image, 1,0 -> 320,240 not in 320,240]
Mar 20 08:03:20 test zmc_m1[5047]: INF [Starting Capture]
Mar 20 08:03:20 test zmdc[4841]: WAR [Can't find process with command of 'zma -m 1']
[root@test /]# zmu -m1 -q -v
Monitor 1(Driveway)
Type : Remote
Host : admin:admin@192.168.1.20
Port : 500
Path : /IMAGE.JPG
Width : 320
Height : 240
Palette : 4
Colours : 3
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 30
Warmup Count : 1
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 3
Section Length : 600
Maximum FPS : 30.00
Reference Blend %ge : 8
Track Motion : 0
Function: 2 - Monitor
Zones : 2
Label : door
Type: 1 - Active
Alarm RGB : ff0000
Check Method: 1 - Alarmed Pixels
Min Pixel Threshold : 10
Max Pixel Threshold : 0
Min Alarm Pixels : 768
Max Alarm Pixels : 0
Filter Box : 0,0
Min Filter Pixels : 0
Max Filter Pixels : 0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 0
Max Blobs : 0
Label : All
Type: 5 - Inactive
Alarm RGB : 000000
Check Method: 0 - Unknown
Min Pixel Threshold : 0
Min Alarm Pixels : 0
Filter Box : 0,0
Min Blob Pixels : 0
Max Blob Pixels : 0
Min Blobs : 0
Max Blobs : 0
*** glibc detected *** free(): invalid next size (normal): 0x0daf0580 ***
Aborted
As added info: network infrastructure as follows:
XP machine 192.168.1.110 (DHCP)
linksys wrt54g v2.2 192.168.1.1<<<<<< Camera 192.168.1.20 (Static)(Wireless Link)
Server linux (where zm is) 192.168.1.4
Mandriva 2006
Posted: Tue Mar 21, 2006 4:52 pm
by jameswilson
the first and last line i dont unders6tand as its capturing. i think we need corey or phil here as this is a streaming issue not a cambazola issue
it is caputring
Posted: Tue Mar 21, 2006 5:04 pm
by antar
Yes it is capturing and motion detection is working i even have a 2 zones defined. i see the frame rate at 2.5fps in monitor but no streaming
i keep getting that glibc error line
Posted: Tue Mar 21, 2006 5:10 pm
by jameswilson
sorry mate thats well over my head but it aint a cambozola thing as stills would work. Im sorry i cant help further but i havnt ever even seen that ever much less fixed it lol
Posted: Thu Mar 23, 2006 4:45 pm
by zoneminder
I think the cropping issue is to do with a zone problem somewhere. If you can print out the Zones table in the DB it may be a bit more obvious. I will have to add a bit more zone sanity checking I think.
