[Ok]can't build database with rpm install with Mandriva 2006
Posted: Thu Mar 23, 2006 11:41 pm
Hi
I try to install ZM 1.22 from rpm on a Mandriva 2006 and follow step by step instruction.
when i run /usr/lib/zm/bin/sminit i get :
I use Mysql 4.1.12.
libmysql14-devel is installed, where can i found this 'chkmysql' ?
[root@VDRBOX Zoneminder]# /usr/lib/zm/bin/zminit
/usr/lib/zm/bin/zminit: line 13: chkmysql: command not found
/usr/lib/zm/bin/zminit: line 18: syntax error near unexpected token `}'
/usr/lib/zm/bin/zminit: line 18: ` }'
I use Mysql 4.1.12.
