Page 1 of 1
Help, problem in STILL MODE - not continuous
Posted: Wed Mar 29, 2006 4:24 am
by victor_diago
hi all and Phil.
Running 1.22.0, ive discovered that if you are in record mode, when you are watching an event that has say 300seconds (5 minutes) and click in the still mode, ONLY THE 4 FIRST IMAGES ARE SHOWN.
All the other images appear as broken. but if you leave it at continuous mode, it will play very well... ive searched and found that when you look at source code, you can see the bug :
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=97&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="97/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=98&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="98/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=99&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="99/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=100&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000100-capture.jpg" width="80" height="60" class="normal" alt="100/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=101&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="101/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=102&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="102/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=103&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="103/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=104&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="104/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=105&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="105/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=106&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="106/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=107&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="107/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=108&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="108/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=109&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="109/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=110&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="110/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=111&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="111/0"></a>
<a href="javascript: newWindow( '/zm.php?view=frame&eid=27719&fid=112&scale=100', 'zmImage', 368, 320 );"><img src="events/7/27719/000000-capture.jpg" width="80" height="60" class="normal" alt="112/0"></a>
</div></td></tr>
LOOK the problem is events/7/27719/000000-capture.jpg
The first 4 images appears ok. The image number 100 also appears ok and the last image too.
Ive searched in zm_funcs.php for any bug in thumb_path but have found NOTHING.
Anyone could help ? or else has this problem ?
Victor Diago
Posted: Wed Mar 29, 2006 4:32 am
by victor_diago
Hi again.
Also ive found that make a video with ffmpeg doesnt work.
this is the result of zmvideo.log
03/29/2006 01:29:49.176710 zmvideo[32496].INF [Creating video file Evento-34-r1-s1.mpg for event 34]
03/29/2006 01:29:49.177301 zmvideo[32496].INF [/usr/local/bin/ffmpeg -y -r 2.30  -i 000-capture.jpg -s  320x240 -hq 'Evento-34-r1-s1.mpg' > ffmpeg.log]
03/29/2006 01:29:49.187563 zmvideo[32496].INF []
AGAIN look the 000-capture.jpg bug.
Victor Diago
Posted: Wed Mar 29, 2006 5:05 am
by victor_diago
Hi again.
i also have the problem with jpeg file quality.
i have tested a lot of numbers, from 20 to 100 and ALL give-me the same quality (seems to be aways 70);
Victor Diago
Posted: Thu Mar 30, 2006 10:03 pm
by zoneminder
The 000 is just a result of the %03d being replaced in the debug output. The actual command is correct. I will fix this anyway in 1.22.1 but it won't change that actually gets run.
Re: Help, problem in STILL MODE - not continuous
Posted: Thu Mar 30, 2006 10:20 pm
by zoneminder
victor_diago wrote:Running 1.22.0, ive discovered that if you are in record mode, when you are watching an event that has say 300seconds (5 minutes) and click in the still mode, ONLY THE 4 FIRST IMAGES ARE SHOWN.
You are correct here. I have just fixed this for 1.22.1, thanks for reporting it.
Posted: Thu Mar 30, 2006 10:22 pm
by zoneminder
victor_diago wrote:i also have the problem with jpeg file quality.
See other thread on this topic.
Posted: Thu Mar 30, 2006 10:29 pm
by victor_diago
Hi phil.
You said "thanks" for me ?
Thanks YOU man, that are developing this fantastic tool.
Also, do you have any patch for this version ? it would be great.
Thanks for all
Victor Diago
Posted: Thu Mar 30, 2006 10:34 pm
by zoneminder
Try this (not guaranteed :lol: )
diff -c -r1.68 zm_html_view_event.php
*** zm_html_view_event.php      17 Jan 2006 21:22:05 -0000      1.68
--- zm_html_view_event.php      30 Mar 2006 22:19:56 -0000
*** 441,465 ****
        if ( $paged && !empty($page) )
!               $lo_frame_id = (($page-1)*$frames_per_page)+1;
                $hi_frame_id = min( $page*$frames_per_page, $event['Frames'] );
        else
!               $lo_frame_id = 1;
                $hi_frame_id = $event['Frames'];
        $sql = "select * from Frames where EventId = '$eid'";
-       if ( $paged && !empty($page) )
-               $sql .= " and FrameId between $lo_frame_id and $hi_frame_id";
        $sql .= " order by FrameId";
        $result = mysql_query( $sql );
        if ( !$result )
                die( mysql_error() );
        $frames = array();
        while( $frame = mysql_fetch_assoc( $result ) )
!               $frames[$frame['FrameId']] = $frame;
        mysql_free_result( $result );
--- 441,465 ----
!               $lo_frame_id = (($page-1)*$frames_per_page);
        else
!               $lo_frame_id = 0;
+       if ( $paged && !empty($page) )
+               $sql .= " limit $lo_frame_id, $hi_frame_id";
        if ( !$result )
        $frames = array();
!               $frames[] = $frame;
*** 471,482 ****
        $thumb_height = (int)round($event['Height']/ZM_WEB_FRAMES_PER_LINE);
        $thumb_scale = (int)round( SCALE_BASE/ZM_WEB_FRAMES_PER_LINE );
!       for ( $frame_id = $lo_frame_id; $frame_id <= $hi_frame_id; $frame_id++ )
!               $frame = $frames[$frame_id];
                $image_data = getImageSrc( $event, $frame, $thumb_scale );
! <a href="javascript: newWindow( '<?= $PHP_SELF ?>?view=frame&eid=<?= $eid ?>&fid=<?= $frame_id ?>&scale=<?= $scale ?>', 'zmImage', <?= reScale( $event['Width'], $scale )+$jws['image']['w']  ?>, <?= reScale( $event['Height'], $scale )+$jws['image']['h'] ?> );"><img src="<?= $image_data['thumbPath'] ?>" width="<?= $thumb_width ?>" height="<?= $thumb_height ?>" class="<?= $image_data['imageClass'] ?>" alt="<?= $frame_id ?>/<?= $frame['Type']=='alarm'?$frame['Score']:0 ?>"></a>
  <?php
--- 471,482 ----
!       for ( $i = 0; $i < $frames_per_page; $i++ )
!               $frame = $frames[$i];
! <a href="javascript: newWindow( '<?= $PHP_SELF ?>?view=frame&eid=<?= $eid ?>&fid=<?= $frame['FrameId'] ?>&scale=<?= $scale ?>', 'zmImage', <?= reScale( $event['Width'], $scale )+$jws['image']['w']  ?>, <?= reScale( $event['Height'], $scale )+$jws['image']['h'] ?> );"><img src="<?= $image_data['thumbPath'] ?>" width="<?= $thumb_width ?>" height="<?= $thumb_height ?>" class="<?= $image_data['imageClass'] ?>" alt="<?= $frame['FrameId'] ?>/<?= $frame['Type']=='alarm'?$frame['Score']:0 ?>"></a>
  <?php
I haven't properly tested this with other event types yet but it seems to work with Recorded events and I _think_ it should ge ok in general.
Posted: Thu Mar 30, 2006 10:50 pm
by victor_diago
Thanks for this Phil.
A question, i should copy this to a file right, then apply patch -p0 ?
Could you post here how do i do that ?
Thanks for now
Victor Diago
Posted: Fri Mar 31, 2006 12:59 pm
by zoneminder
Yes, pretty much.
Create a file with the above patch in and then just run something like 'patch -p0 < patch.txt'. I _think_ that should be all you need to do.
Posted: Sat Apr 01, 2006 4:36 am
by vahan1
Phil,
Do you think you could post the whole php file as an attachment or something? I'm having issues patching it and even if I update it manually, I'm not getting expected behavior.
Thanks a lot.
p.s. newbie, getting setup. had lotsa issues, getting slowly worked out - next big one is streaming into firefox :roll: Thanks for all the hard work and support!
Posted: Sat Apr 01, 2006 4:44 am
by victor_diago
Hi all and phil.
Really, i had problem patching it too.
Should be better to let us download THese files.
Im waiting , much thanks to you.
Victor Diago
Posted: Sun Apr 02, 2006 11:10 pm
by zoneminder
It might be easier at your end but it's more fiddly at my end. I can't usually just upload the file as it will contain elements of other changes so I have to poke around and try and reconstruct the file. It may well be that is why the patch is failing. The best thing is to wait a couple of days for 1.22.1 and apply that.
Posted: Sun Apr 02, 2006 11:52 pm
by vahan1
Thanks Phil.
I got the streaming working, so I'm good for now - looking forward to 1.22.1
Thanks a lot!
v
