The finished instalation, Wireless and Axis 232D, and demo.
Posted: Fri Mar 31, 2006 9:01 am
Hi to all, I want explain about my installation:
I've bought an Axis 232D camera to use it as a CCTV on a construction
I include this elements in a outdoor box (a UPS, one router wireless (linksys wrt54gl-EU with the firmware dd-wrt using WDS), one planar antenna and the Axis 232D camera. In outdoor I put two IR focus for outdoor. (this outdoor box) are Post of 12 meters of height
In other site (300 meters) I put other outdoor box (linksys wrt54gl-EU with the firmware dd-wrt using WDS), one planar antenna , and my debian 3.1 with 2.6 kernel and zoneminder.(for coonexion
This is the first part of the installation but now are running: I must make the motion detection, and much more thinks.
You can visit the installation at:
http://acteavinci.ath.cx/zm
passwd: guest
user: guest
I disable this access after of some Months ,
( I disable the control for the guest user but runs very well), If any want to see I can send a user ) regards!
thanks, thanks (and 40$) and all
One question, There is any date for the 1.22.1 version??
regards!
passwd: guest
user: guest
regards!
