ffmpeg error
Dreamer
ffmpeg error
Post by Dreamer »
OS: Ubuntu 5.10 with ZM adapted from the Debian 'HowTo'
I'm getting an error in zmvideo.log
Creating video file Event-565.mpg for event 565
/usr/bin/ffmpeg -y -hq -intra -r 5.59 -s 320x240 -i %03d-capture.jpg Event-565.mpg > mpeg.log
[mjpeg @ 0xb7e98010]get_buffer() failed
Input #0, image, from '%03d-capture.jpg':
Duration: 00:00:03.7, bitrate: N/A
Stream #0.0: Video: rawvideo, yuvj420p, 320x240, 5.59 fps
Output #0, mpeg, to 'Event-565.mpg':
Stream #0.0: Video: mpeg1video (hq), 320x240, 5.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0xb7e98010]MPEG1/2 doesnt support 5/1 fps
Error while opening codec for stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Error: 1 at /usr/bin/zmvideo.pl line 274.
It seems like the get_buffer() function has failed.
Any ideas as to why?
zoneminder
Site Admin
Post by zoneminder »
I think you need to set an output frame rate of say 25 fps for this codec.
Phil
Dreamer
Post by Dreamer »
The only way I could get this to work was by hard coding '-r 25' into /usr/bin/zmvideo.pl Nothing else seemed to work. I also removed the default setting in OPTIONS.
Anyway, sorted now, thanks for the pointer.
zoneminder
Site Admin
Depending on what version of ZM you have there should be an option, ZM_FFMPEG_OUTPUT_OPTIONS, where you can put this.
Phil
