Page 1 of 1
memory errors
Posted: Mon Apr 03, 2006 10:41 am
by 0utlaw
Hi Guys
I have just downloaded and installed ZM 1.22.0. I have a Logitech Quickcom lying around the office. So to make sure that all is up and running, i tried to use this. I ran the zmu -d /dev/video -q -v and loaded all the settings into ZM. As soon as i clicked save i got this error message '*** glibc detected *** malloc(): memory corruption: 0x0df470c0 ***'. does anyone out there have any odeas as to what the error might be and in which direction i should be aiming at. I have google and have not found much there. I am running Mandrake 2006.
TIA
Terry
Posted: Thu Apr 06, 2006 7:29 am
by cordel
If I recall correctly, I think I seen this error show up when a camera is created but the height and width for the camera are not filled in. For some reason ( The zones don't know how to handle the null data), you can not have those values null when you create a monitor.
Regards,
Corey
Posted: Fri Apr 07, 2006 5:33 am
by 0utlaw
Hi Corey
Thanks for the reply. This is my zmu output. I have added all the values into the zoneminder:
Video Capabilities
Name: Logitech QuickCam USB
Type: 513
Can capture
Can capture subareas of the image
Video Channels: 1
Audio Channels: 0
Maximum Width: 360
Maximum Height: 296
Minimum Width: 32
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 360
Height: 296
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 32768
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL.
I have noticed that gnome meeting has picked the camera up and there is now a shortcut on the desktop. Any ideas as to how to get rid of gnome meeting. or should i just uninstall it.
Terry
