Streaked (sometimes garbled) Images with Kodicom 4400!
Posted: Wed Apr 05, 2006 6:00 pm
Hello ZM friends,
I have this issue with distorted (streaked) images when I 'MOCORD' on 2 cameras pointed to the same object. The streaks last for a single frame at a time and only occur arround the moving object. The lines appear to shaddow the moving object but can be much wider. The artifacts also seem to be only a single field - ie every other line in the frame. Also both images are affected but streaks appear at different times in video sequence.
On rare occasion I get similar garbled images as described in this posting as well sometimes in addition to above:
http://www.zoneminder.com/forums/viewto ... ple+camera
This is my setup:
Hardware and OS:
-Gentoo 2005.1-r1
-zm 1.22.0
-pentiun4, intel chipset
-KODICOM 4400r board
-512 M ram (shmmax set to 301,989,888)
Software (ZM):
- 4 monitors defined - one monitor per bt878 chip - ie channel 1,5 from each cable harness.
- 2 cameras pointed to same object in MOCORD mode with a single zone.
- other 2 cameras are in 'MONITOR' mode not actively streaming.
- All monitors set to limit 10 FPS.
- All monitors set to 640 X 480 RGB24.
- Analyse mode switched off.
- Buffers are 20,5,5,10,1
Still looking for error messages. Will post later.
Here are some examples one from each camera:
This is my setup:
Hardware and OS:
-Gentoo 2005.1-r1
-zm 1.22.0
Software (ZM):
