Grand X Guard Problem.
didi
Post by didi »
Can only view two cameras. If i switch a third Camera on (record, monitor e.t.c.), all the cams are disable. (all device names are red).
All cams using /dev/video0 with channel switch.
My Spec.
BTTV module.
Apr 7 09:20:40 cityserver kernel: bttv: driver version 0.7.108 loaded
Apr 7 09:20:40 cityserver kernel: bttv: using 4 buffers with 2080k (8320k total
) for capture
Apr 7 09:20:40 cityserver kernel: bttv: Bt8xx card found (0).
Apr 7 09:20:40 cityserver kernel: bttv0: Bt878 (rev 17) at 02:01.0, irq: 17, la
tency: 32, mmio: 0xe0000000
Apr 7 09:20:40 cityserver kernel: bttv0: subsystem: 8384:8182 (UNKNOWN)
Apr 7 09:20:40 cityserver kernel: bttv0: using: Grand X-Guard / Trust 814PCI [c
ard=103,insmod option]
Apr 7 09:20:40 cityserver kernel: bttv0: using tuner=4
Apr 7 09:20:40 cityserver kernel: bttv0: PLL: 28636363 => 35468950 .<4>usb.c: U
SB device 3 (vend/prod 0x57c/0x3a00) is not claimed by any active driver.
Apr 7 09:20:40 cityserver kernel: . ok
Apr 7 09:20:40 cityserver kernel: bttv0: registered device video0
Apr 7 09:20:40 cityserver kernel: bttv0: registered device vbi0
KERNEL
Linux cityserver 2.6.8-2-386 #1 Tue Aug 16 12:46:35 UTC 2005 i686 GNU/Linux
running on Debian.
whats wrong?
didi
Post by didi »
I downgraded from version 1.22 .0 to 1.21.4. runs fine. :-)
