Page 1 of 1
kickstart install rpm for ZM..... all you need is..this,...
Posted: Sat Jul 12, 2003 1:05 am
by fernando
ok here is mi rpm list for zm .. you have to set up some perl modules if you want some ectra function like mail o ftp.
%packages
@ Base
cpp
openssh-server
libtiff
gmp
php
libxml2
netpbm
netpbm-progs
perl-DBI
mysqlclient9
libjpeg
perl-Archive-Tar
pspell
gcc
apache
freetype
gd
curl
perl-TermReadKey
mysql
expat
binutils
libpng
mm
perl-DBD-MySQL
php-mysql
openssh
mysql-server
glibc-kernheaders
mc
glibc-devel
mysql-devel
libtool-libs
libjpeg-devel
gcc-c++
zlib
zlib-devel
make
libstdc++-devel
perl
you put this to your kickstart ks.cfg and voila.. i dont have any trouble with this and 0.9.15. i will make a small instalation by modify de @Base inatalation and removing many rpm that are useless..!!
you can remove mc if you dont use it..
Re: kickstart install rpm for ZM..... all you need is..this,
Posted: Tue Jul 15, 2003 9:29 am
by zoneminder
Hi Fernando,
Thanks for this. I planned to create an ISO at some point or a KS config. When I get chance I'll try it from this list.
Cheers,
Phil,
Posted: Tue Jul 15, 2003 10:09 pm
by fernando
sorry i miss some rpm.. :))
%packages
@ Base
cpp
openssh-server
libtiff
gmp
php
libxml2
netpbm
netpbm-progs
perl-DBI
mysqlclient9
libjpeg
perl-Archive-Tar
pspell
gcc
apache
freetype
gd
curl
perl-TermReadKey
mysql
expat
binutils
libpng
mm
perl-DBD-MySQL
php-mysql
openssh
mysql-server
glibc-kernheaders
mc
glibc-devel
mysql-devel
libtool-libs
libjpeg-devel
gcc-c++
zlib
zlib-devel
make
libstdc++-devel
perl
perl-CPAN
this works grate......... from ftp i install rd in 5 minutes.
Posted: Mon Jul 21, 2003 8:32 am
by mikeaer
Please send me an ISO image for that (if its possible with zm include).
Thank you
Posted: Mon Sep 15, 2003 12:26 am
by tips
Hi all
do any one have a kickstart file that I can have
Thank you
by tips
Hi all
Thank you
Posted: Mon Sep 15, 2003 12:27 am
by tips
Hi all
Thank you
